MSD6AL mounting
Old Nov 3, 2007 | 06:50 PM
skippy123's Avatar
skippy123
Cruising
Default MSD6AL mounting
I have look and looked for a place to mount my MSD6AL and cannot find a suitable location . Does any one have any ideas.
Old Nov 3, 2007 | 08:02 PM
roscobbc's Avatar
roscobbc
On top of passenger side inner wheel well, tuck it in underneath fender just above windscreen washer bottle (if yours is fitted there)
Old Nov 3, 2007 | 08:14 PM
Road-Race Vette's Avatar
0Road-Race Vette
Former Vendor
.Thats where i put mine.
Old Nov 3, 2007 | 08:26 PM
Roughrider's Avatar
Roughrider
On my '69 I mounted the MSD box behind the dash panel on the passenger side. Pretty easy installation that way and it's invisible to view.
If you have a '78 or later with a glove box, that isn't an option.
Old Nov 3, 2007 | 09:39 PM
Kid Vette's Avatar
Kid Vette
Old Nov 3, 2007 | 09:52 PM
Brown78's Avatar
Brown78
Look at my AVATAR. It shows were I put mine.
Old Nov 4, 2007 | 08:02 PM
CorvetteDave01's Avatar
CorvetteDave01
Here is what I did.
Old Nov 4, 2007 | 09:53 PM
skippy123's Avatar
skippy123
Cruising
Default MSD Mounting
Originally Posted by CorvetteDave01
Here is what I did.
Thanks This is just what I was looking for.
Old Nov 4, 2007 | 10:05 PM
BigBlockTank's Avatar
BigBlockTank
I put my 6AL behind the front grill, just in front of the A/C condenser. Open the hood and look down from the front, I had the space there. Made a flat plat and mounted with the rubber feet. I thought about the passenger interior, behind the map pockets, but that 6AL makes a bit of noise, and I didn't want that.
KidVette, nice job on your install. Looks good, I got a big block, not quite that much room. (different subject) I had to install my XM receiver under the passenger seat!
Old Nov 5, 2007 | 01:00 AM
standup's Avatar
standup
Originally Posted by BigBlockTank
I put my 6AL behind the front grill, just in front of the A/C condenser...... KidVette, nice job on your install. Looks good, I got a big block, not quite that much room.....
Good place to put it to keep it cool, but I'm curious if you had to add to the supplied wiring ?
Kid Vette's is a nice, clean install, but I think I have a big vacuum tank where he's mounted it........
When I did my research on the Forum, there were some issues with heat affecting the box, so I declined to mount it on the dash firewall or inside the cabin......
.....so with a BB and not altering the supplied wiring, it seemed the best place to mount it was on the passenger inner fender above the control arm.....
.....my bracket is similar to Kid Vette's, but it's shaped to the inner fender......
Old Nov 5, 2007 | 05:13 AM
aworks's Avatar
aworks
Depends on the year. On our 74 we mounted it in the wiper area under the windshield. Fits perfect and gets air from the pressure at the windshield. This won't work on 68 to 72.
Old Nov 5, 2007 | 11:00 AM
DaveP's Avatar
DaveP
Think about putting it in the storage bin behind the pass. seat. Have had mine there for 7 years, close to battery for power, wire under console to dist is hidden, no misfires, no heat probs, etc..
Old Nov 5, 2007 | 12:52 PM
yellow 72's Avatar
yellow 72
St. Jude Donor '09
Plenty room behind the passenger side dash panel. Mounted my Crane ignition box, coil and aux. fuse panel on an aluminum plate there
Old Nov 5, 2007 | 11:32 PM
BigBlockTank
Standup, as with all wiring extensions, solder the connections and heat shrink the open wires. So, yes I extended the stock AL wires to reach where they needed to reach. As for behind the passenger side map pocket, no way for me. No offense to those of you that did, but no way for me. I didn't even think of placing it behind the passenger's seat because of the battery being connected to that compartment. I don't run a regular battery also, just for that reason. I don't want those explosive fumes behind me, I run an Optima battery, period. I'm sure I'll get a few rocks thrown at me for my comments, I'm 51 and been doing this since I was 10 years old. My 1st Corvette was in 1975, it was a 1965 327/375 FI and I was 19 at the time.I am a crew chief on 2 cars (depends on who races that night) that both run 8's in the 1/4 mile. OK boys, fire away...........Tank
To MSD6AL mounting
