Hood Insulation Options
Old Nov 12, 2007 | 01:01 PM
myc3's Avatar
myc3
Default Hood Insulation Options
I have removed the hood from my 77 to allow an upcoming engine swap. The hood has the ugly blanket type of insulation. I have researched on the Forum and it appears that many members have removed the insulation without causing any problems. Since I already have the pins attached to my hood for holding the insulation I am hesitant to cut them off. I would rather install a smooth, clean, thin insulator that could be cut to fit and painted black. Does this type of product exist? Did not find mention of it on the forum or in catalogs?
Old Nov 12, 2007 | 03:03 PM
Durango_Boy's Avatar
Durango_Boy
It would have to be custom. I'm looking into doing the same thing and am deciding between leaving it bare...since I don't have pins, and making a thin smooth good looking blanket to insulate the hood a bit.
Old Nov 13, 2007 | 08:04 AM
myc3's Avatar
myc3
What type of material could be used for a smooth heat resistant blanket? If no one knows of an appropriate material does this mean that the only options are an ugly fiberglass type blanket or nothing? If that is the case how difficult would it be to remove the pins without damaging the hood?
Old Nov 13, 2007 | 08:46 AM
firefighter's Avatar
firefighter
What about the Dynamat hood liner? I've never used one but they seem to be pretty adaptable, cut and stick and all. Here is a link.
http://dynamat.com/products_automotive_hoodliner.html
Just a thought you could also go with a spray on set up like Lizardskin.
http://www.lizardskin.com/index.php
I plan on using lizardskin in a couple of projects here soon, the '65 C-10 and my Blazer also the C3 when I get her.
But when I do the Vette I'm not gonna be worried about authenticity so I will approach things a little different.
Old Nov 13, 2007 | 12:06 PM
myc3's Avatar
myc3
Thanks for the info. I went to the link you suggested and looked at the DynaMat but I saw that it was still 3/4" thick and it was faced with foil. It looks like the DynaLiner is a more appropriate product for me. It is heat resistant, black and can be ordered in a 1/8" thickness. This is important because i am using an AirGap intake and I need clearance.
Now, can anyone tell me how to remove the pins used for holding the hood blanket? They are glued on with an unknown adhesive. How can I get them off without damaging the underside of the hood? I know the liner will cover any mess but I don't want to damage the hood.
Suggestions please.
Old Nov 13, 2007 | 12:29 PM
Durango_Boy
Maybe a heat gun and a flat head screw driver?
Seriously, I would think a heavy duty adhesive solvent.
Old Nov 13, 2007 | 12:43 PM
Mike Ward's Avatar
Mike Ward
As stated here many times before, the OEM insulation blanket was for SOUND reduction purposes, not HEAT.
Old Nov 13, 2007 | 12:55 PM
myc3's Avatar
myc3
I did not know that this issue had been definitively resolved. If it is true that the only purpose was for sound reduction then I will simply remove the pins and paint it black.
What solvent can be used without damaging the fiberglass?
Old Nov 13, 2007 | 02:29 PM
rihwoods's Avatar
rihwoods
Old Nov 13, 2007 | 08:10 PM
corvetteed2shark's Avatar
corvetteed2shark
Default pin removal
I used a hair dryer to get the adhesive soft on mine grabed the pin portion with a pair of pliers and the came right off I used some body shop pre clean to get what was left did a light wet sand and painted
To Hood Insulation Options
