Rotors?!?!?!!!
Old Nov 22, 2001 | 09:38 AM
norvalwilhelm's Avatar
norvalwilhelm
Default Re: Rotors?!?!?!!! (majglc)
majglc I had my rear rotors turned while still on the vehicle.
_______
How do they turn rotors on the car?
Old Nov 22, 2001 | 11:32 AM
Lohkay's Avatar
Lohkay
Default Re: Rotors?!?!?!!! (norvalwilhelm)
you spin the wheels norval. :lol:
Old Nov 22, 2001 | 12:02 PM
mrvette's Avatar
mrvette
Default Re: Rotors?!?!?!!! (Jenny)
Shark rotors are 1.25 thick new....same thickness as current race cars use...
but smaller diameter for the 15 inch stock rims...
I think the shark rotors are FAR superior to any of the newer cars, same as an old A-B body car of the '70's......
I also feel that for a few grooves as long as it's not gouged out, I'd leave them alone....the pads will wear into position fast enough...
IF you really ned replace them...buy American made rotors...I"ll just bet somehow the cheaper rotors are Chinese made, and some of their steel is not so great, I wouldn't take a chance....it's the brakes for christsakes....
GENE
Old Nov 23, 2001 | 02:08 AM
ROD NOCK's Avatar
ROD NOCK
I just replaced my frt rotors for $50 ea out the door from Auto Value Parts. It's sometimes amazing what the common parts stores will stock for your vette!
The reason I replaced mine?! They were getting close to min, and would of served awhile longer. Until I took a good look at the cooling fins, (the veins or webs that are sandwiched between the outer braking surfaces) after picking some of the rust away, they were rusted to paper thin! Nothing like the thought of collapsing rotors to speed replacement! Another sign to look for on older rotors is 'heat spots'. They kinda look like metal zits. Enough of these on a braking surface is a sign I use for fatigue and replacement. They remain and are easier to spot after being resurfaced. My motto with brakes is, "No regrets"! I'd rather be safe than sorry!
Old Nov 23, 2001 | 03:47 AM
Dave68's Avatar
Dave68
Default Re: Rotors?!?!?!!! (redwingvette)
Jenny, One reason they are riveted on is to keep them together during shipping to the "assembly line"
Vette rotors have to be checked to make sure they don't run out more than a few thou. If they do you will have problems with them sucking air into the calapers. The rivets make it so that won't happen; if you can't take them off, you can't put them on wrong.
I agree; runout is sometimes hard to eliminate or reduce to a managable amount. I've heard of shops that can turn the rotors on the car, but have never found one. $69 is not bad, considering what you'd have to pay at a brake shop (>$100)
Old Nov 25, 2001 | 08:59 PM
majglc's Avatar
majglc
norvlawilhelm
They make a machine that does it on the car. Apparently, a lot of the newer imports have non removable rotors. I had it done at the Western Auto it the small town I live near.
