holley commander 950 pro disk
Old Nov 13, 2007 | 09:05 AM
PatsLs1vette's Avatar
PatsLs1vette
Default holley commander 950 pro disk
Can anyone help me i installed a holley commander 950 pro on my brothers monte ss with a 406 .We went to install the disk and disk one is blank,disk 2 and 3 are ok but #1 is blank.Can anyone copy the files and email them to me?Its a used system so its not holleys fault.
Old Nov 13, 2007 | 09:41 AM
Bullshark's Avatar
Bullshark
CI 5 & 8 Veteran
Pat, go to the Holley library site listed below and download Commander 950 software. It is the Pro version
http://www.holley.com/TechService/Library.asp
Bullshark
Old Nov 13, 2007 | 10:58 AM
PatsLs1vette
Hey thanks i never thought i could get it for free Thanks bullshark
Old Nov 13, 2007 | 11:07 AM
Bullshark's Avatar
Bullshark
CI 5 & 8 Veteran
Just make sure your Holley 950 ECU is flashed with the configuration that supports the Pro software. My ECU was an early one and had to have an update firmware flash. I took it down to BG earlier this year at the CF Cruise-in and Holley was nice enough to do it....no charge.
Bullshark
Old Nov 13, 2007 | 11:18 AM
PatsLs1vette
Bullshark
thanks for the heads up ill check
Old Nov 14, 2007 | 10:33 AM
PatsLs1vette
Well downloaded fine but now i got to find an adapter to go from db9 plug to usb since my laptop doesnt use rs232/db9 just usb. Why wouldnt holley use a usb cable?thanks for help bullshark
Old Nov 14, 2007 | 10:46 AM
jimvette999's Avatar
jimvette999
From what I've read, this USB to Serial has worked the most consistently.
USB to Serial Adapter - P/N: 3733
http://www.innovatemotorsports.com/x...cat=250&page=2
$29
Some have tried other brands with limited success, this one I just ordered myself. PM me for a forum you may find helpful.
Jim
Old Nov 14, 2007 | 11:09 AM
PatsLs1vette
yep thats what im looking for thanks Jim,ill check out the other forum too thanks again.
To holley commander 950 pro disk
