Headlights?
Old Nov 14, 2007 | 01:18 PM
jbaron's Avatar
jbaron
2017 C3 of the Year Finalist
Default Headlights?
Hi all,
My headlights don't go up when the light switch is pulled. But , they go up and down perfect when the manual lever under the column is used. Would this be a bad relay?
Old Nov 14, 2007 | 01:27 PM
BKbroiler's Avatar
BKbroiler
Are you sure all the vacuum hoses are hooked up correctly? I don't think you should be able to raise the lights with the lever under the column.
Old Nov 14, 2007 | 01:33 PM
Durango_Boy's Avatar
Durango_Boy
Originally Posted by jbaron
Hi all,
The switch is an over ride giving you the ability to raise and lower the headlights independent of the headlight switch. If the override operates them but the headlight switch does not then you probably have a leak or a connection problem at the switch or on one of the lines to the switch.
I would start there. If the relays or actuators were bad they would not go up and down at the control of the override switch.
Old Nov 14, 2007 | 02:24 PM
jbaron's Avatar
jbaron
So the vac. lines come righT From the switch? What's the easiest way to get at the switch to check connections first?
Old Nov 14, 2007 | 02:51 PM
Durango_Boy
Remove the screws that hold the side of the knee pad to the A-pillar, remove the screws that go into the upped dash pad, and gently pull the panel out a bit. Be careful, because everything is still connected and you don't want to put too much pressure on anything. You will have access to the headlight switch.
The feed from the engine goes to the headlight switch, a jumper goes to the override switch, and a line goes from the override switch to the vacuum tank.
Old Nov 14, 2007 | 05:04 PM
jbaron's Avatar
jbaron
Thanks DB, I'll check it out and see whats up. Then I'll probably put it to sleep for the winter.
Old Nov 14, 2007 | 07:41 PM
jsrajca's Avatar
jsrajca
Hello My 75 When I Got It And Still Now The Lights Worked Like My Brother-in-law Sometimes. They Do Go Up And The **** On Bottom Of Steering Wheel Is To Block Off The Vac. So You Can Keep Them Up. I Just Ordered New Acturators For The Winter Project. Got To Start Someplace. New Guy Johnn R.
11/14/07
To Headlights?
