Interior Light Delay Timer
Old Apr 2, 2022 | 04:21 AM
vertige68's Avatar
vertige68
Hello,
Thank you very much, I will check this fuse. But almost sure it's him because the fuel gauge light no longer lights up either.
I can do it today, I think.
This fuse and the timer.
Anyway, I will come back to you, to all of you to keep you informed and above all to thank you.
Good day to you all.
Old Apr 3, 2022 | 01:32 AM
vertige68's Avatar
vertige68
Hello forum, especially bmotojoe.
Corvette fixed thanks to you, thanks to you bmotojoe, thank you very much.
For timing: after dismantling, timing, nickel.
I continued my research to manage to find that it was the door sensor. Dismantling, cleaning, greasing and everything went into each other.
For the meter, it was the fuse that was HS.
Changed and everything is back to normal.
So, big thanks to all of you.
I still have a problem to solve, but I will find the right place on the forum not to pollute this post.
Just in case, I'm looking for the hose connection diagram for the cruise control on this 1982 Corvette C3.
I wish you all a good Sunday. Here, snow.
Old Apr 12, 2022 | 01:18 AM
vertige68's Avatar
vertige68
Bonjour le groupe GRAND MERCI à vous tous.
La C3 est au top, tout fonctionne de nouveau, éclairage, régulateur.
Merci beaucoup à vous tous
