CS130 VS CS144 Alternator
Old Nov 26, 2007 | 08:04 AM
73383's Avatar
73383
Default CS130 VS CS144 Alternator
I have decided to make the switch to a CS type alternator. I have searched and read all the data on the forum. I have a couple of questions.
1) Is the CS144 case bigger, and if so are there any clearance issues with stock valve covers. Is it a bolt up job.
2) I have found CS130s on line that have been built to 140 amps. Is there any reason to choose the CS144 @ 140 amps over the CS 130 @ 140 amps. Price is not an issue.
3) I want to buy new, so does anyone have part # for the CS130 and the CS144.
Dennis
Old Nov 26, 2007 | 10:02 AM
shafrs3's Avatar
shafrs3
Case is bigger, no clearance issues, not quite a bolt up job.
CS144 came originally designed to provide 140amps, CS130 has issues with reliability. I had a CS130, it died and I switched to the CS140, it's so far out lasted the 130.
No p/n but mine is from a '98 chevy p/u if that helps.
Dennis
Old Nov 26, 2007 | 10:27 AM
davidm_comp's Avatar
davidm_comp
No part number, but I bought my CS144 new from Napa for a '96 Impala, and it fit great without any clearance issues, had to modify the wiring a little but nothing too difficult. I would go with the 144 over the 130, I believe they put out more amps at idle (good if you have electric fans) and they run cooler in the larger case.
Old Nov 26, 2007 | 10:28 AM
Durango_Boy's Avatar
Durango_Boy
The CS130 has a heat weakness which causes the reliability issues. I have seen cars with a CS130 last for 200K miles, so I think it really depends on the conditions, maintenance, and stock electrical system. Some cars or trucks may have been overloaded.
Here is a direct bolt in CS130. No changes will need to be made to the brackets to install this alternator.
http://cgi.ebay.com/ebaymotors/105-A...QQcmdZViewItem
It's brand new with a warranty, and won't even cost $100 shipped.
By the way, if you're ever interested in rebuilding a used CS130, I solved the heat problem with a simple part removal, and all is well. You can do this to a new one as well but you will void the warranty by opening the case.
Old Nov 26, 2007 | 10:53 AM
73383's Avatar
73383
Well I guess I'll go with the CS144. Found this place online.
http://www.alternatorparts.com/CS-144_Special_offer.htm
anyone have any experiance with this place. they also have the wiring adapter with the rectifier, which I need since I don't have a idiot light.
Thanks for all the replies
Dennis
Old Nov 26, 2007 | 10:55 AM
Durango_Boy
I don't think you'll have a problem with that site. Which unit were you thinking of getting? Which amperage?
Old Nov 26, 2007 | 11:01 AM
73383's Avatar
73383
The 140 amp should be enough. I've been running a powermaster SI105 for 2 years. But as its got older its just not putting out enough amps.
Dennis
Old Nov 26, 2007 | 11:26 AM
markdtn's Avatar
markdtn
I bought a CS144 from the local Delco rebuilder to use on my truck. It was just under $200. Used '96 Roadmaster as an application. Hands down I would recommend a CS144 over a CS130. Reliability on the CS130 leaves MUCH to be desired. If it was as simple as removing a part to make it reliable, I promise you GM would have done that a long long time ago.
Old Nov 26, 2007 | 11:29 AM
lil_red_devil's Avatar
lil_red_devil
I went for a CS144 and had some issues with my tall valve covers. Switched to short (stock size) and everything is good
Got my chrome one from Quality Power. Good luck
Old Nov 26, 2007 | 12:26 PM
73383's Avatar
73383
Just orderd the CS144, from the above supplier, 199.85 includes shipping and wiring adapter.
I'll let you know how it goes
Dennis
Old Nov 26, 2007 | 01:12 PM
CorvetteDave01's Avatar
CorvetteDave01
I just did a cs144 from a '96 Impala. I got the alternator for $100 with an exchange unit from Autozone. They also had the plug pigtail for $8. Had to modify the uppertension bracket some, but otherwise went on easy.
Old Nov 26, 2007 | 06:09 PM
comp's Avatar
comp
you have pics of that ?
To CS130 VS CS144 Alternator
