Sealant?
Old Dec 16, 2007 | 03:03 PM
vetteflsurfer's Avatar
vetteflsurfer
Default Sealant?
When I was working on my car's semi restoration over the summer I took off some of the sealant that was cracked and old that were over the windshield wiper mounts.
I have a little bit of water coming in from there I think, just a few drops. I want to reseal that whole area with some new sealant.
Is there any spray can products that are sealants? Most of the sealant in that whole area below the windshield is old and cracked. What should I replace that with? My car is not original and don't need an OEM look.
Thanks guys.
Paul
Old Dec 16, 2007 | 06:01 PM
Alan 71's Avatar
Alan 71
I believe people have suggested using roofing patch from the home supply store. Honest, that's what I remember.
Regards,
Alan
Old Dec 16, 2007 | 06:41 PM
70ZZ3 96LT4's Avatar
70ZZ3 96LT4
Default Rubber type
I am going to use rubberized under coating by mar-hyde that I have bought at WAL-MART. Don't know if they still sell it, but should be available at auto stores. My 70 needs a touch up since it also has the cracks in the old factory applied stuff. Have not done it yet, but it is on my to do list. I have used the mar-hyde to do some touch up on the flat rubber roof of my houses front porch where a similiar stuff had cracks where the flat rubbber roof meets the house. I applied it and then went back a couple days later to layer it on. It worked on this leak. When I do spray my 70 I will do the same apply a complete covering, let it set up and apply more to fill in the cracks. I have the wiper door and grille off, just need to get motivated.
Old Dec 17, 2007 | 08:03 AM
Jud Chapin's Avatar
Jud Chapin
St. Jude 15 Year Donor
St. Jude Donor '11 thru '25
I would use either seam sealer or an RTV product and then just apply it to the leaking source.
Old Dec 17, 2007 | 01:50 PM
75 Hot One's Avatar
75 Hot One
I've used asphalt undercoating in that area. I find that the ordinary asphalt performs & adheres better than the rubberized stuff. Maybe it depends on the brand. A few coats may be required because the material can be fairly thin coming out of the can.
Old Dec 17, 2007 | 02:00 PM
Scott Marzahl's Avatar
Scott Marzahl
If you want to use a caulk tube type sealant, this PL sealant does the trick.
http://www.stickwithpl.com/Products....ashing-Sealant
Old Dec 17, 2007 | 06:00 PM
7T1vette's Avatar
7T1vette
You want to get Butyl rubber caulking. It is black and really, sticky stuff. But it will last a LOOONNNGGG time...even in the sun. It is what the factory used and is a much better choice than silicone. You can find butyl caulk at Lowe's or Home Depot in the tube caulk section. Be sure to clean the surfaces you are going to seal. Also, don't try to move it around much to have it look good...you'll only make a mess. Just put a bead down over the areas you want to seal, then let it flow out on its own.
Old Dec 17, 2007 | 08:14 PM
L82shark's Avatar
L82shark
St. Jude Donor '08
3M Brushable seam sealer. You just brush it on like paint, let it cure and spray over it with undercoating or paint, whatever tickles you. Just make sure its clean as you can get it. It will run down into cracks or crevices and fill them back smooth. Dont have to worry about the overspray either.
Old Dec 18, 2007 | 01:23 AM
vetteflsurfer
Thanks guys for all the advice... Really appreciate it.
To Sealant?
