Problems with new 383
Looking for ideas from you guys on what and how to check this out. My first gut feeling is the intake gasket on the LH side might be off though I spent alot of time making sure everything was perfect. I got AFR 195.
Thanks.
I have new 383 and earlier this year it was burning oil..bad. went through the intake gasket thing, changed heads etc. Turned out the rings were bad and with reversion in the intake, all the cylinders were wet with oil
Happy Holidays and best of luck, Mark
I sat the rings by some hard accelerations and decelerations but that could still be an issue. I will do a compression test tomorrow and report results.
Like I mentioned in an earlier post. I went through the gaskets, changed heads, another new intake, removed again to angle mill the intake where it mates to the head. In an attempt to be sure it was "clamping" the gasket and sealing good. Did the "Italian" break in to no avail. Re. rings, Its always good to have a ring sealing strategy.
But consider this. New cars don't smoke or burn oil and there is no break in procedure. Cast or moly rings will seat under normal driving conditions. The only exception to break in, on a rebuild, is if you use a flat tappet cam. In the past, when cars came with flat tappets from the manufacture. There was little or no break in procedure.
If it smokes....like mine did...after 500 miles...something is wrong (and there was)
Did anyone mention valve seals? Possible you have a bad head...bad seals on one head....
Also what ring pack is in the motor??
Best of luck. I feel for you. I have as well as others here on CF have been there.
If it is the gasket then the only fix is a thicker intake gasket. I used the Felpro one AFR recommended for these heads. Anyone know of thicker one to use that matches up well?
Like I said I fought my problem for months and lots of $$. Eventually took the motor out went through it again. Fresh hone and a set of file fit Total Seal rings. All good now.
Just another thought..have you checked the vacuum? A low reading woulld be a clue
How many miles on the engine?
Dino or synthethic?
AFR's new or used? If new, unlikely its a valve seal issue.
You might want to do a leak down test...but I would get 2-3,000 miles on the engine first and see if it clears up...
In my case an oil ring was bad. A leak down didn't show anything was wrong. In fact the excess oil in the cylinder bumped the numbers.
I might have jumped the gun since only number one is solid black. The rest on the LHS look reasonable. The compression check was: 1(170)3(172)5(170)7(169)2(174)4(177)6(16 9)8(172).
So I think now I just have a problem with #1 maybe at the intake gasket. #5 looks pretty black also.
My reason for asking, if you filled up a dry motor with oil and checked the level before priming the system, that could account for a lot of the oil. Lots of oil in the lifters, galley, on top of the heads and in the filter.
If those plugs were new on the engine build..they look OK, again for 300 miles.
You're motor is not really broke in. It may take 2-4,000 miles for the motor to settle down. Those plugs are not oil fouled/ More like fuel rich. I prefer a projected tip plug, Like and NGK or Accel. I used to swear by AC's. But AC Delco is not a GM product. GM sold off this unit. Hence I like NGK's or Accel's.
What carb are you running?
Mark
Intake gasket not sealed well on the left side.
