Gutted the CAT!
Old Jan 1, 2008 | 11:06 AM
Luster's Avatar
Luster
Default Gutted the CAT!
Not too bad of a job. I've sure done worse jobs!
Anyway, I'm impressed with how much better the car runs. Better throttle response, better power, MUCH better sound. (Deeper, "throatier", louder!)
Definitely feels like I have much more power.
The back bolts were the first ones off. Came off very easily.
Front bolts had to come off with an impact wrench.
I did pre-soak the bolts with PB Blaster for about 30 minutes prior to removing them.
Once I got it off, I took a long pry-bar and busted out the internals.
Looked like partially burned charcoal.
Very easy to break out.
Cleaned it up, painted silver with Dupli-color 1200* Hi-Temp paint.
Re-installed.
P.S. It's a lot easier to remove the bolts if you loosen the heat shield and remove the connection to the air tube.
Any questions, feel free to ask....
Old Jan 1, 2008 | 04:06 PM
LanceB's Avatar
LanceB
Go true duals and it will make an even bigger difference...
Old Jan 1, 2008 | 05:13 PM
Luster's Avatar
Luster
I'll probably go with true duals at some point in the future. This was my best fix for the money (zero dollars!)
Old Jan 1, 2008 | 06:28 PM
wombvette's Avatar
wombvette
Last time I did that, I made strings for my fiddle.
Old Jan 1, 2008 | 07:21 PM
lars's Avatar
lars
I just took my gutted cat, threw it in the trash, and got a nice, new functional stock cat and installed it. How sweet it is to pass emissions with no problem and have a car that runs right... You guys in the farming States with no emissions testing don't have much longer of that freedom... you're going to be looking for "emissions restoration parts" within just a few years...
Old Jan 1, 2008 | 07:32 PM
yellow 72's Avatar
yellow 72
St. Jude Donor '09
Leave the converters alone. If you want to hot rod your stuff buy a pre catalytic car or run the high flow stuff, it works!
Removing this type of emissions is what has the Feds panties in a knot and will force stricter enforcement on all of us
Old Jan 1, 2008 | 09:14 PM
chris75stingray's Avatar
chris75stingray
it took me a second to get that
Old Jan 1, 2008 | 10:15 PM
FB007's Avatar
FB007
Magnaflow makes some high flow stuff.
Old Jan 1, 2008 | 11:34 PM
DVNTST8's Avatar
DVNTST8
From: if you have a ? on my avatar, please contact me directly, you spineless twit
St. Jude Donor '09
here in Az, they realized finally that classic automobiles provide such an insignificant amount of contibution to the emissions problems that if you register as a collector vehicle, emissions isn't required.
Just can't be your DD or work vehicle...my junk's coming off soon.
Old Jan 2, 2008 | 12:53 AM
RIJVETTES's Avatar
RIJVETTES
I just added a new 3 inch Magnaflow. No significant restriction on flow and I gotta pass smog in California. Car Craft did some dyno testing recently on a 400 hp engine and found a modern cat lost only about 5-10 hp at very high rpms. Good reason to go green and forget about the old pellet style cats that were corks in the system.
Old Jan 2, 2008 | 09:36 AM
RippoDippo's Avatar
RippoDippo
What year did this mess start?
Old Jan 2, 2008 | 09:38 AM
lars's Avatar
lars
Old Jan 2, 2008 | 11:22 AM
TexasYankee's Avatar
TexasYankee
Breaking a Federal law was never my idea of fun.
A free flowing CAT is the way to go IMO.
Old Jan 2, 2008 | 05:28 PM
Wrecked82's Avatar
Wrecked82
And getting rid of EGR valve gives you nothing either.
Old Jan 2, 2008 | 08:29 PM
1FSTZ06's Avatar
1FSTZ06
The irony is I'm looking at your avatar that is bleeching flames and smoke into the atmosphere...sort of hard to take your advice
I know you're pre 75 but you clearly throw out more emissions with the rocket ship you've built
Old Jan 2, 2008 | 09:16 PM
yellow 72's Avatar
yellow 72
St. Jude Donor '09
Maybe, but if I were to run an under car exhaust I would run a couple of high flo cats even tho I don't legally have to...
To Gutted the CAT!
