Header Gasket Question Again
Old Jan 2, 2008 | 06:09 PM
Silver00V6Camaro's Avatar
Silver00V6Camaro
Default Header Gasket Question Again
Ok well im about to order some new gaskets for my headers. I have vortec heads and a cheapo set of headers from autozone i belive they are flowtec or a cheap set of headmans. Anyway I keep blowing the header gasket on the passenger side header the driver side is fine. So what header gakset is needed for vortec heads. I have used mr. gasket and the fel-pro designed to fit vortec head fel-pro number 1404 and it blew out in a week. What is the best gasket and what is the correct port do I need round, square, oval or what. Im tired of blowing header gaskets and dont want to get new headers.
Old Jan 2, 2008 | 06:48 PM
Scott Marzahl's Avatar
Scott Marzahl
This sounds like it is possible that the flange on that side may not be truely flat. You can try these extra thick Remflex Graphite gaskets, they compress 50% to seal.
http://catalog.remflex.com/product_p/rf2011.htm
Old Jan 2, 2008 | 07:00 PM
Silver00V6Camaro
Old Jan 2, 2008 | 07:13 PM
Silver00V6Camaro
what about these http://store.summitracing.com/partde...127+4294904129
Old Feb 8, 2008 | 08:50 PM
L82shark's Avatar
L82shark
St. Jude Donor '08
Did you get the Percy's? I was looking at those too....
Old Feb 8, 2008 | 08:57 PM
1Fordman's Avatar
1Fordman
Check into copper gaskets, I have used them with good success in situations where no other gasket would last.
Old Feb 8, 2008 | 09:00 PM
Jclgodale3's Avatar
Jclgodale3
Originally Posted by Silver00V6Camaro
I've had very good luck with those
Old Feb 8, 2008 | 09:26 PM
comp's Avatar
comp
did you re-torque after a hot and cool ???? i have used spray copper coat (several heavy coats) but still check those bolts
Old Feb 9, 2008 | 11:59 AM
Silver00V6Camaro
No. I actually got some Flowtech Real Seal Aluminum Gaskets from Seco. They work great stoped the leaks just make sure to retorque after they have been heated and cooled.
To Header Gasket Question Again
