balancer decision
Old Feb 7, 2008 | 10:04 PM
AWilson's Avatar
AWilson
Default balancer decision
I am trying to decide which balancer to buy for my Gen-1 383 buildup. This is a street car build under 400hp that started as a 327.
After looking on Summit I came up with these 2. But they seem to be very different because of the diameters and especially the weights.
SO what do I need to learn to decide?
Pioneer Street Performance Balancers:
Part #'s
PIO-872001
PIO-872002
Appreciate any insight
Old Feb 7, 2008 | 10:43 PM
stock76's Avatar
stock76
I just put a 6" ATI Super Street Damper on mine last weekend. The Super Street is not SFI approved but my old L48 won't ever rev that high for that long anyway. I was pretty impressed with the way it was made (right here in the USA). It's pretty innovative in that you can unbolt the damper fom the center hub and bolt an ATI Super Damper on the existing hub if you ever want to upgrade. You do have to hone it a bit to get it on. they give you the tolerances in the installation instructions.
Both Summit and Jeg's carry them. Check prices. When I got mine Jeg's was a lot less than Summmit for the same one.
Pioneer has a very good reputation, too, from everything I read on other car forums. If I'm not mistaken they are made in Australia.
Old Feb 7, 2008 | 11:29 PM
Scott Marzahl's Avatar
Scott Marzahl
Al,
Myself, I would first look at a GMPP 394709 8" hi performance nodular iron damper for your application. Used several over the years on some high horse and high RPM motors. The 872002 Pioneer would be an option, they make decent stuff. The cast iron GMPP would be a decent option as well.
http://store.summitracing.com/partde...5&autoview=sku
EDIT: I just checked Scroggins and the 394709 is listed at $125
Good Luck,
Scott
Old Feb 7, 2008 | 11:35 PM
jackson's Avatar
jackson
LIke Scott, I suggest 8" too.
383 comes either internal or external balance ... each requires different damper ... choose accordingly.
Old Feb 7, 2008 | 11:42 PM
Scott Marzahl
Well I assumed it was internal for the P/N I gave. Jack, don't you ever sleep
Old Feb 7, 2008 | 11:47 PM
jackson's Avatar
jackson
Not original, but appropriate: rust never sleeps.
Old Feb 8, 2008 | 06:51 AM
AWilson's Avatar
AWilson
Good point Jackson, I forgot to mention that my engine is Internally balanced.
Why is 8" better than the 6.750? Reason I ask is the 6.750 I believe will work with my stock timing chain cover as the tab or timing pointer that is welded on the cover won't work with a 8" one.
Old Feb 8, 2008 | 09:15 AM
jackson's Avatar
jackson
put the 6 3/4" on ... not that much difference. 8" has bigger mass & better dampening. But if you have tab welded for 6 3/4 then get that. I run lite 4 lb dampers on true race circle track motors ... but yours is a mid-perf street motor so I suggest a "normal" mass.
Old Feb 8, 2008 | 10:06 AM
ARCH's Avatar
ARCH
Is there any noticeable performance to be gained with a lightweight damper. Are you giving up and dampning ability?
Old Feb 8, 2008 | 10:15 AM
jackson's Avatar
jackson
because it's lighter ... motor will accel & decel quicker ... but less dampening of crank etc ... something for nothing is rare.
Old Feb 8, 2008 | 10:51 AM
ARCH's Avatar
ARCH
I understand there would be compromises most of the time, but was just wondering with these new high performance parts if they have been able to make the leap to something for nothing with either new design or materials, or is all about the weight?
Old Feb 8, 2008 | 11:17 AM
Scott Marzahl
It's all about money and the aftermarket IMHO, all the high dollar dampers are mostly overkill for a street car.
Old Feb 8, 2008 | 11:18 AM
Scott Marzahl
You could just remove it and weld on a new tab for a 8" like a L-79 uses. Paragon carries them.
Old Feb 8, 2008 | 09:07 PM
AWilson's Avatar
AWilson
Scott,
Are you sure a stock L79 has a 8" balancer?
Old Feb 8, 2008 | 09:17 PM
Scott Marzahl
Yes, I have a L-79 in my '67 with a new reproduction 8" finned balancer$$$
Old Feb 9, 2008 | 07:27 AM
AWilson's Avatar
AWilson
Are you talking about this Paragon part?
PR #: 805
GM #: 3817173
$350
Old Feb 9, 2008 | 12:35 PM
Scott Marzahl
Tab should be 1763 $18
I'm not sure if the finned damper was carried over to '68 though, I need to check on that.
I didn't see that 805 part number but that is the correct GM number. Here is the replacement version for reference. THe -709 would still be a better piece.
Replacement balancer not finned.
http://www.corvette-paragon.com/cata...5-F6EDC0B9DFF7
To balancer decision
