Tach question
Old Jan 3, 2008 | 04:10 PM
81fixerupper's Avatar
81fixerupper
Default Tach question
What is usually the culprit when the needle on the tachometer goes all the way around and stays in one spot? Also works correctly intermittently. 1981 stock vette automatic transmission
Old Jan 3, 2008 | 06:31 PM
spedaleden's Avatar
spedaleden
Either bad connection or new PC board for tach. The board was bad on mine. Wuld not work when cold but worked fine when it warmed up. Took a soldering iron to all points and eliminated the cold solder joint.
Hope this helps
Old Jan 3, 2008 | 07:57 PM
L82shark's Avatar
L82shark
St. Jude Donor '08
Lots of posts on here about that. Could be a variety of reasons. Do a search for "tach board" on you will see them. If you decide to replace the tach board pm me, I can send you some step by step directions given to me by some others if you need it.
Old Jan 4, 2008 | 12:24 AM
cruise83's Avatar
cruise83
you may want to bypass the tach filter to see if it is bad before buying the board.
To Tach question
