preventing rusty rotors
Old Jan 5, 2008 | 10:59 AM
AWilson's Avatar
AWilson
Default preventing rusty rotors
My car will sit a lot. Probably only driven 6 months out of the year, maybe 1000 miles a year.
I was wondering if there are options to keep the rotors from rusting over? I know it probably doesn't hurt anything but If I can prevent it at a reasonable cost then why not.
Old Jan 5, 2008 | 12:19 PM
7T1vette's Avatar
7T1vette
No. Anything you do to prevent rust would be bad for the brake pads. You could spray a light oil on the rotors...but your pads would pick that up when you apply them. If the car is inside [out of the weather], don't worry about it; one apply and the rotors will clean up where the pad operates. The other areas will rust anyway. The only other way to "prevent" rotor rust is to buy rotors that won't rust (some stainless additives to the steel)...or plate the non-used rotor areas with chrome or nickel.
Old Jan 5, 2008 | 12:22 PM
dannyman's Avatar
dannyman
Keep your vehicle in a climate controlled environment. Pretty much need to keep the car in a separate garage with temp/humidity control.
Not to realistic for most of us. The amount of corrosion on the rotors is really not a factor. I get corrosion overnight on my daily driver!
Old Jan 5, 2008 | 12:36 PM
Lee H's Avatar
Lee H
You can have them acid dipped and zinc washed at your local plater, not to expensive and will prevent the rust from forming on most surfaces except where the pad rides.
Old Jan 5, 2008 | 12:49 PM
garage-ghost's Avatar
garage-ghost
My rotors never rust while in storage. Even in a non-climate controlled garage.
Old Jan 5, 2008 | 01:28 PM
lars's Avatar
lars
My car sits on a lift in the garage for 8 months at a time. I've never seen any rust on the rotors - they stay clean and rust free with no maintenance. Unless they're getting wet, why would they rust...?
Old Jan 5, 2008 | 01:47 PM
dannyman's Avatar
dannyman
Chicago, Illinois is on a closer latitude to Kingston, Ontario. Dampness and moisture in the air is what we deal with year round. Believe me when I say that my daily driver rotors rust overnight.
The advantage of living here is shovelling snow.
Old Jan 5, 2008 | 03:37 PM
FB007's Avatar
FB007
Once around the block and they are clean.
Old Jan 5, 2008 | 05:24 PM
AWilson's Avatar
AWilson
Ok, maybe I am being too picky. Car will be kept in a garage. We will see what happens.
Old Jan 5, 2008 | 08:15 PM
ENG40's Avatar
ENG40
I always take the car for a short ride after washing it to dry the rotors. Other than that if it's stored inside you shouldn't have any rust.
To preventing rusty rotors
