1972 LS5 air cleaner
Old Jan 6, 2008 | 01:28 AM
shelbyluva's Avatar
shelbyluva
Default 1972 LS5 air cleaner
When I bought my car, it had a GM open element air cleaner (like on a LS6/LT1) on it rather than the dual snorkel that is correct for a '72 454. I bought a repo from Eckler's that is made by Classic Headquarters and it doesn't seem to fit. I have interference at the rear with the distributor cover, and it also touches the elbow in the P side valve cover. It seems large and low. Any advice? Is this a poor reproduction or might there be another problem?
Old Jan 6, 2008 | 10:17 AM
HamadUP's Avatar
HamadUP
St. Jude Donor '08
The factory original dual snorkle cleaner housing has a small recess on the back side to clear the distributor shield. Yours propably dont have that recess.
Old Jan 6, 2008 | 10:38 AM
7T1vette's Avatar
7T1vette
If you don't mind having a repo (no problem, unless you are a purist), just dent it where you need to and touch up the paint as needed. The hardware will work just fine, when you get the clearances fixed.
Old Jan 6, 2008 | 07:36 PM
shelbyluva's Avatar
shelbyluva
Actually, the repo does have the recessed area in the back, yet there is still interference. Has anyone here used this repo successfully?
Old Jan 7, 2008 | 01:57 AM
HamadUP's Avatar
HamadUP
St. Jude Donor '08
Are you sure you are having the correct distrobutor cover for your engine? Can you post a picture?
Old Jan 11, 2008 | 02:36 AM
shelbyluva's Avatar
shelbyluva
Default air cleaner pics
The 1st 2 pictures are the air cleaner that came on the car when I bought it. It looks to be like a LS6 air cleaner and has the AC Delco silkscreen on the top of the lid.
The 2nd 2 pictures are the repo air cleaner from Eckler's. I had to remove the distributor cover because it isn't possible to have both installed at the same time. It seems to sit lower than other pictures of originals I have seen and interferes with the driver side valve cover fitting.
Old Jan 11, 2008 | 12:15 PM
voat's Avatar
voat
I have a '72 454 also and I just checked and it appears from your pictures the brackets that mount the distributer cover are reversed. On mine where the plug wires go through the bracket are closer to the air cleaner (front of the engine), the bolt holes to mount the distributer cover are closer to the distributer. Try reversing the brackets and you may have enough clearence to mount your dual snorkel. Also, if your going all original/stock, your valve covers should be painted the same color as your engine (Chevy red). They were not chrome on 1972 big blocks.
Old Jan 11, 2008 | 01:00 PM
mudbone64's Avatar
mudbone64
From: I'd like to propose a toast... to internal combustion and wind in the face.
Maybe you could try bending the spark-plug wire brackets back a little. They are fairly flexible. I don't know if it will help or not but here's a couple of pics of mine:
Old Jan 11, 2008 | 05:32 PM
shelbyluva's Avatar
shelbyluva
Default diameter
Thanks for the help and the wonderful pictures. It doesn't look like the contours on the lid of the air cleaner are the same between your pictures and my pictures of the repo, but that doesn't necessarily mean that the base is wrong. It almost looks larger though then I look at the air cleaner in relation to the thermostat housing.
Does anyone know the diameter of an original?
Old Jan 11, 2008 | 08:43 PM
danthony's Avatar
danthony
2024 C3 of the Year Finalist - Unmodified
Maybe you have the wrong aircleaner. The cover does not look correct???? Is the manifold and carb stock? Oh - The engine will sound meaner when you open it up with the open air cleaner!
Also, see how your aircleaner covers the water neck, that is way to wide a diameter, I think this cover is definitely not correct!!!
Heres another pic for you.
Old Jan 11, 2008 | 10:56 PM
CCrane65's Avatar
CCrane65
The 72 air cleaner is made for a 14" filter. That one looks like it was made for a 15" filter. Like maybe 73 and later.
As others have said, the cover does not look right either. There should be a small sharp ridge on the part that rises up.
cc
Old Jan 11, 2008 | 11:00 PM
shelbyluva's Avatar
shelbyluva
I measured the repo air cleaner element and it is 14". The top of the air cleaner lid is 17", and I was wondering if anyone knew what an original measured at on top.
It is a stock intake and Rochester carb.
Old Jan 12, 2008 | 06:14 PM
CCrane65's Avatar
CCrane65
Mine is 15.5 inches across and just under 3" tall.
cc
To 1972 LS5 air cleaner
