Glass bead them or find a old AC spark plug cleaner machine to do the same thing except a much smaller item to use. They could be expensive as antique collectors for garage items may have the only ones available. Similar to air hose machines and gas pumps. I do it for my scooters too. Another point to cover is that those plug gaskets are available separately. I dont know where you can still find them, but E bay?
DON'T EVER Glass bead clean spark plugs and put them back into a engine you like! The glass beads will lodge deep in the plug between the electrode and shell and slowly empty out into your combustion chamber as the motor runs. I DON'T CARE HOW WELL YOU CLEAN THEM THE BEADS ARE STILL THERE! Plugs are cheap, stock up on them now.
Thanks for the responses. The plugs are Platnium 4 prong in a BMW and were replaced just last spring. Doing a valve cover gasket replacement that the BMW dealer wanted $1,000 plus to do. The money I save doing gasket job myself will pay for new plugs, but if they look good I'm going to reuse.
