Steering coupler
Old Jan 10, 2008 | 02:28 PM
popeye73's Avatar
popeye73
Default Steering coupler
When installing a steering coupler which part goes on the steering box shaft the rag joint or the other half of the coupler?
73 vet
Old Jan 10, 2008 | 02:41 PM
Scott Marzahl's Avatar
Scott Marzahl
The coupler is often referred to as the "rag joint". It can only go on one way, I believe your '73s splined steering box shaft should have a flat indexing spot that will mate to the female portion of the coupler.
Old Jan 10, 2008 | 02:45 PM
dobroman2001's Avatar
dobroman2001
73 vet
Here's some pictures of a '76 that may help:
http://s189.photobucket.com/albums/z...man2001_photo/
Old Jan 10, 2008 | 03:57 PM
68/70Vette's Avatar
68/70Vette
The steering box input shaft is smaller in diameter than the steering column. It's not possible to put the flex joint (rag joint) in backward.
Maybe I misunderstood the question.
Old Jan 10, 2008 | 04:44 PM
popeye73's Avatar
popeye73
Got it guys thanks
Old Jan 10, 2008 | 04:56 PM
GTR1999's Avatar
GTR1999
Just a quick point of reference. The C2's, 63-66 std rags had the same size spline on both ends. One end was riveted to the flange but the spline was the same. I know this doesn't pretain to your question, just throwing it out there.
To Steering coupler
