radio bolt up help
Old Jan 11, 2008 | 01:32 PM
ace_cobra's Avatar
ace_cobra
Default radio bolt up help
when i took my old radio out it wasnt secured down to anything, and now that i am putting a new corvette one in, i would like to have it properly secured. I noticed that there were two holes on the bottom of the guage plate, and i was wondering if they are supposed to be used, and if the radio should be bolted up anywhere else?
Old Jan 11, 2008 | 02:36 PM
SIXFOOTER's Avatar
SIXFOOTER
If your putting in a unit with the ***** like a stock unit that will take care of the front. The back side usually has a ground strap to screw to the floor or a side bracket that will stabilize the back.
Old Jan 11, 2008 | 06:21 PM
Alan 71's Avatar
Alan 71
On my 71 there's a strap riveted to the passenger side of the fiberglass transmission hump that has 1 bolt which screws into the side of the radio. This stabilizes the radio. The two nuts on the front (behind the *****) fasten the radio to the gauge bezel.
Regards,
Alan
Old Jan 11, 2008 | 07:06 PM
Duke94's Avatar
Duke94
Old Jan 12, 2008 | 12:02 AM
ace_cobra's Avatar
ace_cobra
is that the back of the radio
Old Jan 12, 2008 | 12:06 AM
7T1vette's Avatar
7T1vette
Photo is of the right side of the radio under the removable front panel.
Old Jan 12, 2008 | 12:35 AM
ace_cobra's Avatar
ace_cobra
so how does the guage cluster bolt to the centre console, and do i have to unscrew my guage cluster if the radio is in and the two front bolts arent in?
Old Jan 12, 2008 | 02:50 AM
7T1vette's Avatar
7T1vette
The two studs on the bottom of the gauge cluster panel get inserted into the metal support band at the front of the front console. Then you do some voodoo to get the two flanged-headed nuts threaded onto those studs and tightened. PITA If you have small hands, you can get the nuts on through the front access panels on either side of the console.
Old Jan 12, 2008 | 08:43 AM
ace_cobra's Avatar
ace_cobra
ok are studs actually bolts or are they welded into the guage face, because mine doesnt have the studs, and does the nut thread from inder the reinforcement?
Old Jan 12, 2008 | 10:18 AM
Duke94's Avatar
Duke94
This photo shows the studs sticking out the bottom of the gage cluster (looking up from the bottom) and the console is tipped up and pulled back a little. The radio support bracket I showed in previous post is on the right toward the back.
Old Jan 12, 2008 | 12:13 PM
red70stingray's Avatar
red70stingray
Someone posted this picture when i was having radio trouble, and i saved it. It shows how to access the bezel bolts with a long extention and a swivel
Old Jan 12, 2008 | 04:00 PM
Duke94's Avatar
Duke94
The hard part is getting the damn nuts started!
Old Jan 12, 2008 | 04:13 PM
Alan 71's Avatar
Alan 71
Red 70,
That's a great picture that shows the answer to an almost impossible situation.
Regards,
Alan
Old Jan 12, 2008 | 07:52 PM
red70stingray
I wish i remember who posted it so they can get the credit....
To radio bolt up help
