Adding power antenna???
Old Jan 13, 2008 | 11:38 AM
Derby98's Avatar
Derby98
St. Jude Donor '09
Default Adding power antenna???
I am adding a aftermarket radio to my 71 coupe & I am wondering how hard is it to mount a aftermarket power antenna?
I know how to wire it up etc...just wondering is it a PITA to access the antenna cavity?
Old Jan 13, 2008 | 11:45 AM
Eddie 70's Avatar
Eddie 70
Ci 6, 8 & 10 Veteran
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15
I loosened the muffler and worked around it. Not too bad of a job. One thing I would do if I were to do it again would be put a switch in line with the UP power so the antenna does not go up and down all the time. The reason I mention this is I usually just ride with the top down and hardly ever turn the radio on because I cannot hear it anyway and my car is quiet when running at speed as far as exhaust noise is concerned. Wind noise kills the radio.
Old Jan 13, 2008 | 11:54 AM
Derby98's Avatar
Derby98
St. Jude Donor '09
Great. Glad it's not too hard. Adding to the TO DO LIST.
Old Jan 13, 2008 | 12:56 PM
Stoge's Avatar
Stoge
I replaced the power antenna on my '79 with an OEM one from TLD. I wasn't able to get the muffler to budge, so worked around it. It really was a pretty easy job.
Old Jan 13, 2008 | 01:01 PM
SmokinBBC's Avatar
SmokinBBC
Which antenna conversion are you guys using?
Old Jan 13, 2008 | 07:04 PM
Derby98's Avatar
Derby98
St. Jude Donor '09
so is there a far amount of room in there?
I don't have to worry about getting a "compact" antenna or anything?
Old Jan 13, 2008 | 07:21 PM
murraybs's Avatar
murraybs
Don't want to hijack, but I think I should also ask which antenna kits you're using?
I've seen universal ones at my FLAPS, but I'm unsure about using them.
Anyone got any experience with that?
Old Jan 13, 2008 | 07:40 PM
Derby98's Avatar
Derby98
St. Jude Donor '09
I am planning on using either A) Hirschmann or B) Metra antenna
I have a Hirchmann in my 85 Jaguar & it has worked great for 20 years.
Both are universal fully automatic.
Old Jan 14, 2008 | 10:55 AM
Stoge's Avatar
Stoge
There is a fair amount of room, but if smaller antennas stay farther away from the muffler, IMO they are better. Less heat gets to them.
Old Jan 14, 2008 | 10:58 AM
Derby98's Avatar
Derby98
St. Jude Donor '09
Thanks, I will attempt to find a compact design & also will plan to wrap it it some for of head sheilding as a added measure against heat.
Old Jan 14, 2008 | 11:26 AM
l1dws's Avatar
l1dws
I see that Mid America also has a power antena for like 90 bucks.
I was wondering if anyone has had good results with them...Thanks
To Adding power antenna???
