Edelbrock Top End Package
Old Jan 24, 2008 | 03:13 PM
FRSTR90's Avatar
FRSTR90
Originally Posted by foxymophandlpapa
aaaaaaaaaaaah sorry, I though that was the "I agree" sign, not the "bs" flag (my personal favorite). Good, thanks for the heads up. Where are the specs for that cam? Summit doesn't list any of the specs that come with it. Thats why I chose the comp cam that I did.
What do you think of the Comp cam that I selected with that package?
Here are the specs for the hydraulic flat tappet Performer RPM cam:
Intake Duration at 050 inch Lift: 234
Exhaust Duration at 050 inch Lift: 244
Duration at 050 inch Lift: 234 int./244 exh.
Advertised Intake Duration: 308
Advertised Exhaust Duration: 318
Advertised Duration: 308 int./318 exh.
Intake Valve Lift with Factory Rocker Arm Ratio: 0.488 in.
Exhaust Valve Lift with Factory Rocker Arm Ratio: 0.510 in.
Valve Lift with Factory Rocker Arm Ratio: 0.488 int./0.510 exh. lift
Lobe Separation (degrees): 112
As you can tell, it is far from mild. The cam is truely high performance street cam. If you are looking for ***** to wall performance with little maintenance (vs. the solid flat tappet), I assure you that you wont be disappointed. This is not to say it is the most powerful set-up, but a very respectable set-up.
As far as the cam you selected, it will definitely work. I don't have any experience with it, but based off of videos I've seen, it sounds healthy. I think you ought to give the Performer RPM a try, if it is too much cam then I'd fall back on the 286. If you are worried about mileage, the performer RPM cam shoudln't even be an option. Also, if you did go with the performer RPM, make sure you have a good cooling system because it will definitely need it!
Old Jan 24, 2008 | 03:39 PM
captainmorgan's Avatar
captainmorgan
Does anyone have a video or sound clip of a 350 car with this cam in it? I would like to hear how the idle is.
Old Jan 24, 2008 | 03:58 PM
LeMans Pete's Avatar
LeMans Pete
St. Jude Donor '13-'14
Ever seen this?:
Intake Duration @ .050 Recommended CR
210 8.5-9.5:1
210-220 9-9.5:1
220-230 10:1
230-240 10.5-11:1
240 and up 11:1 or greater
For an engine thats gonna be ~10:1 compression, both these seem a bit large, which would hurt my low end. Is that table above a little conservative?
Old Jan 24, 2008 | 04:27 PM
FRSTR90's Avatar
FRSTR90
I've never seen that table. I would say they are a little conservative. My dad's engine measured out to be 10.26:1 compression with the stock 76cc head which actually measured out to be 74cc. Keep in mind, his heads have a lot of work into them and I would bet money they outflow edelbrock's heads. Does this answer your question?
Old Jan 24, 2008 | 04:30 PM
FRSTR90's Avatar
FRSTR90
I wish I could get you a video right now. Unfortunately, he is in the process of installing a DeWitts radiator and he really hasn't had much time to work on the vette.
EDIT: Here is sound clip of edelbrock's cam from their website in a 383: http://www.edelbrock.com/automotive_...Camaro2006.mp3
They don't rev it high enough for the engine to really talk to ya, but I think you can get the idea.
Old Jan 24, 2008 | 04:47 PM
DRIVESHAFT's Avatar
DRIVESHAFT
Now compare those numbers with a modern cam with similar .050" #'s. Here are the specs for a Lunati Voodoo cam. Part # 60104
Product Line: Lunati Voodoo Camshafts
Part Type: Camshafts
Cam Style: Hydraulic flat tappet
Basic Operating RPM Range: 2,200-6,400
Intake Duration at 050 inch Lift: 233
Exhaust Duration at 050 inch Lift: 241
Advertised Intake Duration: 276
Advertised Exhaust Duration: 284
Intake Valve Lift with Factory Rocker Arm Ratio: 0.504 in.
Exhaust Valve Lift with Factory Rocker Arm Ratio: 0.525 in.
Lobe Separation (degrees): 110
Compare the advertised duration numbers. The Voodoo cam is 30° shorter that the generic Edelbrock grind.
It will give all of the top end performance of the Edelbrock cam and MUCH better manners down low.
There is a reason people talk bad about those cams. As cam grinders go, Edelbrock makes great intake manifolds.
Buy your cam from a cam company.
Old Jan 24, 2008 | 05:06 PM
LeMans Pete
How does that have much better manners down low? Its got greater lift with more overlap, that would seem to me that it would kill low end power.
Old Jan 24, 2008 | 05:22 PM
DRIVESHAFT's Avatar
DRIVESHAFT
Lift doesnt hurt low speed manners.
The Voodoo has 60° of overlap.
The Edelbrock cam has 89° of overlap.
Old Jan 24, 2008 | 05:33 PM
FRSTR90's Avatar
FRSTR90
The cam is meant for high RPMs. I've already stated that. What I am saying is that it is no slouch in the lower-end. I've personally driven the car, I've ridden in the car at speeds above 155 MPH with a TH400 and 3.70. If you do the calculations, that is about 7500 RPMS with a P255/60r15. I know what an engine package like this is capable of.
Old Jan 24, 2008 | 05:38 PM
DRIVESHAFT's Avatar
DRIVESHAFT
Nobody said that it didnt work well at high RPM's. They said it was a pig down low.
You may believe it works well, and Im glad your happy with it, but if you havent driven
the same vehicle with a modern cam in it, you dont know the difference.
And by the way, you arent turning 7500 RPM's with that cam either.
Old Jan 24, 2008 | 05:49 PM
andylmusic76's Avatar
andylmusic76
for most applications i find that too expensive IMHO. you can buy a brand new pair of vortec heads from jegs, a brand new POLISHED aluminum intake manifold from professional products, nice chrome headers on ebay, a nice cam from summit, etc. etc. and it will cost much less...atleast it did for me. i seem to have been getting lucky lately with such good deals
Old Jan 24, 2008 | 05:50 PM
FRSTR90's Avatar
FRSTR90
They make a hydraulic roller version that supposedly produces even more power with less overlap. I am sure that cam would be a good cam to install. Please don't come a rip on a cam if you haven't experienced it for yourself. The thread clearly specifies if anyone has had any experience with this cam which I do. BTW- What says the engine wont turn 7500 RPM's?
Old Jan 24, 2008 | 07:50 PM
  #33
DRIVESHAFT's Avatar
DRIVESHAFT
The hydraulic roller is a different story. That cam isnt too bad.
A flat tappet hydraulic cam, the size of the the RPM cam just isnt big enough to make power at 7500. HP will peak somewhere around 6000 rpm or so and it will be done by 6500.
Old Jan 24, 2008 | 09:16 PM
  #34
LeMans Pete
Well I will admit my stupidity in hopes you'll explain. I thought smaller LCAs gave you greater overlap? Go easy on me
  #35
GlockGuy's Avatar
GlockGuy
Default Trick Flow top end kit
Yesterday I ordered this Trick Flow top end kit with roller cam from Summit. These heads have double valve springs. I found a source for the Comp Cams roller lifters on -bay that saved me about $200.00. I also got zero intererst on the summit card which helped.
http://store.summitracing.com/partde...5&autoview=sku
I also orderd this summit intake:
http://store.summitracing.com/partde...0&autoview=sku
Old Jan 24, 2008 | 09:39 PM
  #36
63mako's Avatar
63mako
St. Jude Donor '08-'09
I tend to agree with Driveshaft that there is no way that hydraulic cam can pull 7500 rpm especially in high gear. It is almost impossible to get much over 6000 rpm out of a hydraulic cam without valve float. Maybe 6500 or a little more with a rev kit. Also power will drop off quickly after 6000 RPM just when you are hitting the areodynamic wall. Maybe the speedometer has the wrong gear and is reading incorrectly.
Old Jan 24, 2008 | 09:53 PM
  #37
63mako's Avatar
63mako
You are right, the smaller LSA will give you 2 degrees more overlap but the advertised duration is huge on the Edelbrock cam compared to the Lunati. That is where the drastic overlap difference is. The Edelbrock cam has a more gradual ramp rate (old school). The Lunati is a more modern grind with a faster ramp rate. This seems to be the direction the cam companies are moving in and it will pull better power without sacrificing lower end torque. I think the downside of the fast ramp rates are accelerated valvetrain wear. Really think this is one of the reasons you are seeing more wiped lobes in the hydraulic flat tappet cams recently. If you want fast ramp rates, big lift and streetability roller cams are the way to go. JMHO.
To Edelbrock Top End Package
Old Jan 24, 2008 | 10:13 PM
  #38
Silver00V6Camaro's Avatar
Silver00V6Camaro
I had it the idle is rough and choppy. Its not that good of a cam does nothing below 3000 rpm.
Old Jan 24, 2008 | 10:28 PM
  #39
LeMans Pete
Sorry FRSTR90, but its sounding like the concensus is that that cam is not very good compared to what is available today. I definitely agree with this statement:
Edelbrock makes great intake manifolds. Buy your cam from a cam company.
I'm definitely leaning towards that package, but I'll need to search around for a cam. Those Lunati grind looks good, but I'll try and get some more opinions first. Thanks for the help guys.
Old Jan 25, 2008 | 12:19 AM
  #40
FRSTR90's Avatar
FRSTR90
Hmmm, it is a little bouncy sometimes. I wasn't the driver, and trying to look across the steering wheel to see the speedometer is a bit of a challange. I would say it was reving atleast 7000.
Where is Millington? Maybe we can get together sometime, and you can see for yourself. I think you'll be quite surprised on how well the engine runs.
