AIR pump belt ?
Old Jan 17, 2008 | 10:39 PM
EPF's Avatar
EPF
Default AIR pump belt ?
1980. Should the water pump pulleys and the crank pulleys be so close together that I can't get the AIR pump belt on?
Thanks,
Eric
Old Jan 18, 2008 | 12:35 AM
Ak. Mal's Avatar
Ak. Mal
From: Kansas City, MO ...I'd like to go fishing and catch a fishstick. That'd be convenient. - Mitch Hedberg
I just replaced both water pump pulleys last weekend on my '80 and I had no trouble getting the belts in place. Something doesn't sound right.
Old Jan 18, 2008 | 05:08 PM
ENG40's Avatar
ENG40
Have you got any pictures?
Old Jan 18, 2008 | 10:07 PM
guitarcrazy02's Avatar
guitarcrazy02
There shouldn't be any clearance issues. I could swap mine on and off as fast as I could loosen the tension on the belt.
Old Jan 20, 2008 | 10:04 AM
EPF's Avatar
EPF
So you did not have to remove the water pump pulleys to get the AIR pump belt on? On my 80 the water pump pulleys and the crank shaft pulleys are very close together. Almost touching. Do I have them on right?
Old Jan 20, 2008 | 06:21 PM
Ak. Mal's Avatar
Ak. Mal
There are two water pump pulleys. The first one to go on is a double groove that runs the alternator and a/c. The second pulley is a smaller diameter single groove that fits over the front of the first pulley. When assembled they don't like like two separate parts. The smaller diameter groove is what runs the smog pump.
I just ran out and checked my car. You shouldn't be having problems slipping a belt onto the water pump pulley.
Old Jan 20, 2008 | 10:48 PM
EPF's Avatar
EPF
The main problem was that I am an idiot! I was trying to put the AIR pump belt in the wrong place. I am all set now. Sorry for the confusion. I will make sure I have my $#!+ together before I confuse anyone else.
Thanks for your help.
Old Jan 20, 2008 | 11:41 PM
7T1vette's Avatar
7T1vette
{It's not like the rest of us haven't done something like that before.}
Old Jan 21, 2008 | 01:11 PM
EPF's Avatar
EPF
Thanks man. Nice Car!
To AIR pump belt ?
