Smoking at start up
Old Jan 18, 2008 | 04:48 PM
kmobrien76's Avatar
kmobrien76
Default Smoking at start up
Smoking at start up, that a sign of valve seals needed? Popping thru the carb and running blah above 2K rpms.
Going to bring it to the shop soon, just want to have a clue before I drop it off and say "have a ball with my checkbook."
Kevin
Old Jan 18, 2008 | 06:06 PM
7T1vette's Avatar
7T1vette
Could be valve seals....could be timing problems. But you don't need to say "Have fun with my checkbook." They'll do that anyway.
Old Jan 18, 2008 | 06:28 PM
mchar's Avatar
mchar
How much smoke? What color? Does it disappear upon warmup? Does the popping thru the carb disappear when warm?
Mark
Old Jan 18, 2008 | 07:54 PM
kmobrien76's Avatar
kmobrien76
Mark,
Dissappears upon warm up.
Popping thru the carb happens when leaving from a stop light and I mash the gas..
Kevin
Mark
Old Jan 19, 2008 | 02:47 AM
Aggitated Monkey's Avatar
Aggitated Monkey
The smoke on start is valve seals. You will mostlikly find this only happens on cold starting and the oil has had a chance to seep into the cylinders. My '80 has the problem also.
The popping is a tuning problem and could be any number of things. You may look for oil fouled plugs.
Old Jan 19, 2008 | 08:14 AM
Jud Chapin's Avatar
Jud Chapin
St. Jude 15 Year Donor
St. Jude Donor '11 thru '25
You never mentioned the color of the smoke. If it's blue, that's oil. My '76 had it on start up and a change of the valve stem seals fixed the problem.
Old Jan 19, 2008 | 09:49 AM
kmobrien76's Avatar
kmobrien76
Everything points to valve seals, timing and tune up needed. That's what's in order. I'll suggest it to the repair shop then get their diagnose, estimate, get it done so it's ready for the better weather!!
Kevin
Old Jan 19, 2008 | 03:51 PM
Jud Chapin's Avatar
Jud Chapin
Kevin
Good deal!
To Smoking at start up
