Rear end almost finished!! (pics)
Old Jan 19, 2008 | 06:00 PM
L82shark's Avatar
L82shark
St. Jude Donor '08
Default Rear end almost finished!! (pics)
Finally got everything cleaned and painted and have been stuffing it back under as fast as I can go so I can get the new exhaust system on. Will put the halfshafts and fuel tank back in tomorrow. To all of you on the numerous other threads I started on this project, I say thanks for the advice and assistance!!! It now has a new body mounts, rear suspension, fuel cell, rear wiring harness, rebuilt differential and the undercarriage and frame have been cleaned and painted. Here are some before and after pics:
before:
after:
Disregard the Camaro only parking sign on the wall.....
Here is the Camaro today, she is slightly pissed, to say the least. and yes, my cars do talk to me! Don't yours?
Old Jan 19, 2008 | 06:11 PM
Eddie 70's Avatar
Eddie 70
Ci 6, 8 & 10 Veteran
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15
Looking nice and clean. Nice transformation.
Old Jan 19, 2008 | 06:15 PM
r44s's Avatar
r44s
Sometimes the vett is the only one who will speak to me.
Old Jan 19, 2008 | 10:32 PM
Glassbowtie77's Avatar
Glassbowtie77
Looks good, nice work.
Old Jan 20, 2008 | 12:09 AM
ZL1powr's Avatar
ZL1powr
Nice work. really looks nice.
Old Jan 20, 2008 | 02:16 AM
murraybs's Avatar
murraybs
No, but I sure do "talk" to my cars!
Fantastic lookin' rear-end there, about how long did it take?
Old Jan 20, 2008 | 03:40 AM
AKruizer's Avatar
AKruizer
L82 That's looking GREAT!!!! My 75 is in the middle of a similar transformation, a lot more cleaning up before things start going back on. I'm curious what you used to detail the underbody and your differential cover... looks to me like you did a great job there, I'd be thrilled if mine turned out half that good
Old Jan 20, 2008 | 04:52 AM
rclinton's Avatar
rclinton
Veteran: Marine Corps
Man,
That is an outstanding job. I've got three more days here in the Box then I can get to work on mine. I too would like to know what you used on the differential, it looks great. Side note. Is the stack up of the strut bar bolt a mock up? I didnt like the looks of the nut threaded only 1/2 way on.
Bob
Old Jan 20, 2008 | 07:47 AM
Jud Chapin's Avatar
Jud Chapin
St. Jude 15 Year Donor
St. Jude Donor '11 thru '25
You da man!
Old Jan 20, 2008 | 08:29 AM
AllC34Me's Avatar
AllC34Me
Senior Member
St. Jude Donor '10
Very nice, very clean. You may have just inspired me to tackle this one as well. Another item for the list which, at this point, is getting long.
Old Jan 20, 2008 | 09:51 AM
L82shark's Avatar
L82shark
St. Jude Donor '08
no, nothing is tightened all the way up yet. Just making sure all the pieces go back to together before I torque them up. Also have to get it back on the ground to make sure the ride height and everything is right before final torque.
Pressure washed everything under the car, but that didnt do a whole lot. Used a steel brush and scotchbrite pads with carb and brake cleaner. Another useful tool is a wire wheel stuck into my die grinder, it will strip stuff down in no time flat. Hopefully will finish up today and get the exhaust and ac box started. Thanks for compliments, it was one nasty car underneath, had to sweep, vacuum the shop floor 3 or 4 times. Next time I will put plastic underneath so I can pull out an throw away without all the sweeping.
Old Jan 20, 2008 | 11:07 AM
78Vette-SA's Avatar
78Vette-SA
Sweet! Good work...
Old Jan 20, 2008 | 11:15 AM
CJ 77's Avatar
CJ 77
Niiiiicccccceeeee!
Old Jan 20, 2008 | 04:14 PM
Alan 71's Avatar
Alan 71
Nice Work!!! Camaro looks quite pissed off.
To Rear end almost finished!! (pics)
