Best block
Old Jan 24, 2008 | 01:31 PM
lars's Avatar
lars
Mark -
I'll send you an e-mail response with some recommendations for you. You don't want to run aluminum block in your street car - if you want affordable reliability and durability, run as much iron as possible...
Old Jan 26, 2008 | 11:40 AM
sly vette's Avatar
sly vette
Thanks Lars
Mark
Old Mar 10, 2008 | 09:04 PM
lars's Avatar
lars
Mark -
Just so you know - I haven't blown you off on this... I have sent you replies to all your e-mails with detailed info and recommendations. However, all e-mails sent to you and "replied" to your address come back as "undeliverable."
Lars
Old Mar 11, 2008 | 01:37 PM
sly vette's Avatar
sly vette
Thanks Lars...I get all my E-Mails even though some will come back as undeliverable.
Old Mar 11, 2008 | 01:45 PM
VIPERBARON's Avatar
VIPERBARON
From: Guantanamo Bay, Cuba (home in Colorado Springs)
I went with a 1969 350, 4-bolt main block out of a truck. Realitivly high nickle content. Cost me $100 out of Craigs list.
Bored it out to .040 over.
Forged SRP pistons.
Forged 4340 Eagle crank.
Forged 4340 "H" rods (5.7 inch)
Alum heads.
ARP bolts & studs.
Wish I could have budgeted for an alum block.
Old Mar 11, 2008 | 07:58 PM
ajkogut's Avatar
ajkogut
Default Used cores are easy to come by...
Originally Posted by sly vette
I would to eventually like to put in a stroker(SB) in my car. This will be an extended project due to the fact that I currently have a 388cid that runs pretty good, and it will be built as funds become available but Eventually I KNOW I will want more power
Can anyone suggest the best block to start a stroker project?
Thanks,
Mark
Many will answer your question with very expensive aftermarket blocks by Dart or World products and those are very good starting points. But for a street car, a normal old GM core can be a very good starting point for a stroker motor. It can be argued that a "seasoned" core has already done all the "core shifting" it will do and, therefore, is a better starting point. This phenomenom (theoretically) is more prone to happening on new blocks.
Depending on what displacement you're starting with, you can get a 350 4 bolt or 400 2 bolt (said to be stronger than 4 bolt, in this case) core for a couple hundred bucks and have a perfectly good starting point for a stroker motor. In either case, these should hold up to plenty of streetable horsepower and should last you years to come.
Of course, I have nothing against $3k or $4k blocks, but I think they're often overkill for a street car. Let the firestorm begin...
Old Mar 11, 2008 | 09:31 PM
SmokedTires's Avatar
SmokedTires
Cruise-In III Veteran
St. Jude Donor '05
Sly I have a 388 sbc and love it! I went with the Dart block and was very impressed when it arrived. Many people run the 427sbcs with great success on the street as well
Old Mar 12, 2008 | 01:58 PM
sly vette's Avatar
sly vette
Thanks for all the input everyone! I am going to take my time with this.
Old Mar 12, 2008 | 02:14 PM
vettfixr's Avatar
vettfixr
The only thing I'm going to add to this thread is that Lars' engines give me a stiffy.
Old Mar 12, 2008 | 03:25 PM
spookytooth's Avatar
spookytooth
Not only that, the man has a bar in his garage.
To be able to sit at the bar, have a beer and slobber over a cool
motor - priceless
