Which Harmonic Damper/Balancer do I need?
Old Jan 21, 2008 | 01:47 PM
stock76's Avatar
stock76
Default Which Harmonic Damper/Balancer do I need?
I noticed that the orange elastomer ring on my harmonic balancer has some broken off areas. It is still working ok for the moment but it is the original one. My car is a 1976 L-48, original engine, automatic w/air with around 118,000 miles. It's probably time to replace it before it goes and causes other (more expensive) problems. The car is only driven about 5,000 miles a year at most so I don't need any real exotic replacement, but I really don't want to put some poor quality Chinese piece of crap part on it either. Can anyone give me the GM replacement part number and /or suggestions on a good quality damper to replace it with?
Thanks in advance for your advice.
Old Jan 21, 2008 | 01:54 PM
Belgian1979vette's Avatar
Belgian1979vette
Why not search for a used good one.
Old Jan 21, 2008 | 03:46 PM
jackson's Avatar
jackson
I don't suggest a used one or an import.
Seems it's not your primary transport ... suggest you pull it off ... take it to a good GM parts dept ... have them match it with a GM part ... even if they have to order. If that fails, come back here with all damper dimensions.
In addition to several diameters ... there are subtle differences in thickness that might foul correct belt alignment.
GM or good equivalent brand is likely to outlast us.
Old Jan 21, 2008 | 07:03 PM
stock76's Avatar
stock76
Thanks for the replies. I don't think I would trust a used one, might not get anything better than what is on there now. I want to make sure I don't get an import, so I was hoping if I couldn't get the information on what brand to get, if not GM, at least I could get some feedback on what brand not to get . It's no fun doing the same repair twice (unless there are ten years or so in between).
Old Jan 21, 2008 | 07:18 PM
Scott Marzahl's Avatar
Scott Marzahl
Pioneer makes a decent part. No reason you can't get a new GM replacement though. You can always have your original rebuilt too.
http://www.damperdudes.net/
Old Jan 21, 2008 | 10:25 PM
stock76's Avatar
stock76
Thanks for the link. Is Pioneer a US made product? I see that Summit sells them.
To Which Harmonic Damper/Balancer do I need?
