Dented Headers
Old Jan 22, 2008 | 06:04 AM
brian76's Avatar
brian76
Default Dented Headers
I was just wondering if anyone knows if I can repair a pretty big dent in one of my header primary pipes. It's a Hooker Super Comp 1 3/4" diameter tube and it's around the bottom where it starts to bend up towards the top of the motor (around the starter area). Can a muffler or a machine shop help me out here? Looks like a rock hit it pretty good. I have 600 bux in these things ,and don't want to do it again. Thanks
Old Jan 22, 2008 | 06:39 AM
69small block's Avatar
69small block
you may be able to weld a small bolt on the dent then heat the area and pull out
Old Jan 22, 2008 | 06:48 AM
1fastC3's Avatar
1fastC3
If they are ceramic coated or chrome plated I don't know if theres whole lot you can do with out spending some big bucks. If they are uncoated, I think an exhaust shop would be able to fix it, either buy doing what 69small block said or cutting out the dent and welding in a patch. good luck and sorry to hear about your bad luck.
-alex
Old Jan 22, 2008 | 10:31 AM
brian76's Avatar
brian76
-alex
Yeah , they're Jet Hot coated- I thought that maybe they could put some type of expander on the inside and push out, but i don't know
Old Jan 22, 2008 | 11:36 AM
Scott Marzahl's Avatar
Scott Marzahl
Other than trying to pound it out from the inside, a body shop "stud gun" and slide hammer might work. It won't be good for your coating though.
Old Jan 22, 2008 | 12:28 PM
7T1vette's Avatar
7T1vette
Drill and tap in center of dent for a slide hammer puller, then re-weld hole; stud weld and use dent puller; replace the header. Those are the only three options I can think of. I doubt that you can get any kind of expander mandrel into that pipe area to use one.
Old Jan 22, 2008 | 01:47 PM
comp's Avatar
comp
what about these "ball" tools for repairing tubes i have read about ???
Old Jan 22, 2008 | 02:01 PM
Ironcross's Avatar
Ironcross
Never work, those are for mandrill bends shaping the tubes before there cut and fitted. I flattened a 2 1/8 primary on a set of my Super comps . I just cut the section out and merely patched it with a matching shaped piece cut from another bent tube.
If your not set up to do this a good muffler shop that does high performance stuff should be able to repair it .
Old Jan 22, 2008 | 02:17 PM
comp's Avatar
comp
what is the ball tool to fix intake runner tubes ???
Old Jan 22, 2008 | 10:34 PM
vetteaddic's Avatar
vetteaddic
I never tried but have heard, If you can seal the ends some how and put a few pounds of air pressure in the tube that is bent, then heat the area to a cherry red the compressed air will pop out dent.
Old Jan 22, 2008 | 10:49 PM
427Hotrod's Avatar
427Hotrod
2020 C2 of the Year - Modified Winner
2020 Corvette of the Year (performance mods)
C2 of Year Winner (performance mods) 2019
2017 C2 of Year Finalist
Just a wild thought..but I wonder if the *paintless dent repair* type guys could get enough leverage to work out something as heavy gauge as a header tube? Probably have to pull header...but it might be possible.
JIM
Old Jan 22, 2008 | 11:59 PM
Ironcross's Avatar
Ironcross
Those Hooker headers are much thinner that you think for the amount of money they cost. I was under the impression of heavy material too until I bent up some BB Super Comps with 2 1/8 primaries. Not only was it "super" thin {ironic} it was full of little rust holes in both the bends and the collector. And the Camaro was never in bad weather. We welded them up and placed them back in service. Surprised the hell out of me as to the poor quality. One note, these were not coated however. I`m not sure but coating may help this condition.
Old Jan 23, 2008 | 11:09 AM
brian76's Avatar
brian76
Thanks , what I think I'll do is take it to the machine shop and see what they think. If they say it's useless then I'm off to the muffler shop.
Old Jan 23, 2008 | 11:12 AM
brian76's Avatar
brian76
By the way, does anybody know where I can buy 1 3/4" primary headers other than Hooker? 1 5/8" don't cut it. Hooker is so expensive. Thanks
To Dented Headers
