Anyone have any ideas on how to repair the passenger side corner on My dashpad? It is the only damage on it and I'd like try to repair it as opposed to spending $250.-$300. for a new repro. Is it possible to do and have it look good, or am I wasting my time?
Hey Man, I was in the same boat and I recently bought something called a "Dash Shield" from Ecklers. It was like 109 bucks (they matched the lowest price I found on the internet) and it basically just glues on top of the old dash. THIS IS NOT a piece of vinyl that you have to glue on, this is a rigid piece that you just set on top of the current dash. For the price, it was a pretty good deal to me.
Since your dash pad is otherwise in great shape , consider this.
The bad end is not very visable when door is closed,so I would suggest trying to paint the exposed end the correct shade of red.
2nd. option would be to buy a very poor condition dash pad as cheap as possible and cut out a patch to glue on. Then paint the patch red.
This gives a cheap way out and you may be comfortable for now.
Then just keep looking for a DEAL on a pad and replace with a new one.
Then sell your old one and recoup some of the money spent on the new one.
Patch the end with a flexible body putty or use some [knead-type] JB Weld epoxy to fill in the vinyl loss on your panel. If you can find a piece of scrap vinyl with similar "grain" appearance, wait until your repair is fairly stiff--but not hard--and press the scrap piece onto the surface to transfer the grain pattern. Let it harden, paint it (same color vinyl dye if you have it, or matching model paint), and reassemble. Damage in that area is easy to fix and the repair is hard to notice.
Had the same problem on my '77. Got "Bondo" brand name product from the auto body supply store. This product is to be used on the plastic bumpers for cracks, abraisions, etc. Two part and you only have about 6 minutes to work with it. Mold it around and into the the corners of the cracked ends. Make sure you use an exacto knife to cut or bevel the edge which will give you a clean blend. and then sand down to shape it. To get the "pattern-leather" look, you can use a nail to scratch in the pattern, this is really hard to do, but it is doable. Use the proper dye for your car and voila...you're done. Took me about two 1/2 hours of work-start to finish! I did have the dash out of the car which made the work much easier. Take your time and Good Luck
Domer.
An alternative for you is to buy a vinyl repair kit and follow the enclosed instructions.
If you are not comfortable doing it yourself go to a marina or car dealership. Most use a vinyl repair mobile service to make these sorts of repairs to seats and interior trim. Ask the used car manager, typically responsible for this type of work. Good luck.
