rear leaf
Old Jan 27, 2008 | 10:23 PM
auctionman256's Avatar
auctionman256
Default rear leaf
hi can a 1980 mono leaf spring be used on a 75 vette?
Old Jan 27, 2008 | 11:22 PM
I'm Batman's Avatar
I'm Batman
St. Jude Donor '07
Nope, different spring mounts. VB&P has mono-leaf springs for 63-77, 78/79, 80-82 and a good reputation.
Old Jan 28, 2008 | 08:14 AM
Van Steel's Avatar
Van Steel
Premium Supporting Vendor
Yes it can. Any fiberglass spring will fit on any C2 or C3 car. The only thing that is different is the mounting plate that bolts to the diff.
VBP list it 3 ways so you get the correct mounting plate. All fiberglass springs are the exact same wideth where it bolts to the diff.
Old Jan 28, 2008 | 08:34 AM
dmaaero's Avatar
dmaaero
The mounting plate and bolt sizes are different, the springs are the same
Old Jan 28, 2008 | 12:29 PM
I'm Batman's Avatar
I'm Batman
St. Jude Donor '07
I stand corrected. I thought the mount changed for the 80-82 "batwing" differential.
Old Feb 6, 2008 | 11:59 AM
VBP's Avatar
VBP
St. Jude Donor '07,'13
Default Vbp Rear Springs
The mounts are the same for the fixed rate rear springs we sell that are similar to stock.
We sell adjustable set-ups that allow you to adjust the spring rate as well as the ride height, and those have different mountings due to the rear end differences.
Everyone is kinda right on this one
Pattie
VBP
To rear leaf
