LS1 Conversion update
Old Apr 29, 2008 | 05:01 PM
jackson's Avatar
jackson
sweet & simple, good job dan
Old Jun 23, 2008 | 09:10 AM
vettedan's Avatar
vettedan
Thank you!
Here's a Video with the the new compcam/ lifters installed.
http://www.vetteworksonline.com/acrobat/ls1cam01.mpg
Old Jun 23, 2008 | 09:57 AM
Budman68's Avatar
Budman68
Cruise-In VII Veteran
St. Jude Donor '07
Nice job...Looks like your almost there.
Old Jun 23, 2008 | 11:22 AM
burners's Avatar
burners
Cruise-In IV Veteran
Cruise-In V Veteran
That's pretty cool, Dan. That cam sounds pretty mean! You are definitely making good progress especially actually driving it a little. What's with the sun being out and shining? Take pictures of that rare occasion as well.
Old Jun 23, 2008 | 08:36 PM
vettedan's Avatar
vettedan
Thanks Eric and Buddy,
Were getting very little sun up here. This engine will have plenty of extra power.
I have to add extra bit of pressure line to get the Steeroids hooked up. I currently getting the body line up with the frame. Lots of work!!!
Old Jun 23, 2008 | 09:55 PM
78Vette-SA's Avatar
78Vette-SA
Dan,
Looks great. can't wait to see the end result.
Just as an aside and you probably already knew this and changed some things, but the 600+ lift is a decent cam and stock springs won't cut it. So hopefully under those valve cover either are another set of heads or you at least another set of springs. And the 335 duration I assume was a typo and you meant 235.
Keep rockin'
Old Jun 23, 2008 | 10:50 PM
vettedan's Avatar
vettedan
Originally Posted by 78Vette-SA
Dan,
Keep rockin'
Joe- Thanks for the compliment. Opps I fat fingered the key. 234. I using Patriot Performance Gold Dual Spring Kit. The stock springs are very whimpy. My buget can't afford heads yet.
Old Jun 23, 2008 | 11:24 PM
78Vette-SA's Avatar
78Vette-SA
I figured that.
You're good to go and you'll be tearin' em up. You're going to love it.
Old Jun 23, 2008 | 11:40 PM
vettedan's Avatar
vettedan
Joe,
Do you have anymore pics of the 81 FrankenSport LS6SC/6spd/SRIII?
Old Jun 24, 2008 | 07:09 AM
78Vette-SA's Avatar
78Vette-SA
Originally Posted by vettedan
Joe,
Enough to bore you to sleep! Plus I have dozens more not posted.
http://vettetech.com/projects/c3gs/c3gs.htm
Just scroll down and follow the sequences. If you need any additional info or shots of anything to help you out, just let me know.
Joe..
Old Jun 24, 2008 | 01:16 PM
72LS1Vette's Avatar
72LS1Vette
Joe..
Joe,
Do you have any videos or sound clips of the engine running? I'd love to hear that supercharged motor through those side pipes.
Rick B.
Old Jun 24, 2008 | 05:43 PM
78Vette-SA's Avatar
78Vette-SA
I don't want to hi-jak Dan's thread on the incredible job he's doing, but I had posted this last summer before I was done. I need something newer with the car completed.
Thanks...
http://www.vettetech.com/misc/frankensport.wmv
Old Jun 24, 2008 | 06:03 PM
  #33
holley505's Avatar
holley505
DAN.
Nice build...welcome to the world of
C3s w/ LSx
With that cam and stall you should run about .4-.5th better than me.
I have 3000 stall ... comp 224 .581/.581 cam...C5 manifolds also... stock 3.36 rear on 275/60R15
Old Dec 14, 2008 | 09:53 PM
  #34
Evette76's Avatar
Evette76
Thank you!
Hey what exhaust is on the car in this video? I thought I saw a side pipe?
Old Dec 18, 2008 | 11:35 PM
  #35
vettedan's Avatar
vettedan
Currently I have open exhaust, soon it will be side pipes.
Old Dec 19, 2008 | 09:42 AM
  #36
mrvette's Avatar
mrvette
:l urk:
Old Dec 19, 2008 | 12:46 PM
  #37
weez58's Avatar
weez58
I've never seen one of these sumps in person and I'm trying to figure out how fuel gets into the sump when the fuel tank gets low? Just by sloshing over the top? Are there some holes that don't show in these pictures? I know they work, so I must be missing something. Inquiring minds need to know....
Thanks,
Bob
