Broken fiber optics
Old Feb 2, 2008 | 11:37 PM
ENG40's Avatar
ENG40
Default Broken fiber optics
Is there a way to splice a broken fiber optic cable or does it have to be replaced? I have a broken cable that goes to one of the rear lights and would like to repair/replace as long as the console is apart.
thanks....Rick
Old Feb 3, 2008 | 01:29 AM
rumblefish's Avatar
rumblefish
7th Gear
Default fiber optic repair
I had fairly good luck with just cleaning up the broken ends, cutting the strands to a uniform length, inserting them in a little bit of brass tubing, pushing the ends in until they bottom out against each other, then crimp the ends to hold the cable in place. a piece of heat shrink might also work. You may loose a little bit of brightness but its a lot cheaper than getting a whole new cable.
Old Feb 3, 2008 | 05:19 AM
wallifishrmn's Avatar
wallifishrmn
How bright are the fiber optic spots on the console supposed to be. Mine are all working but they don't seem very bright--are they easily seen on a bright sunny day. Is there someway to make them brighter? Thanks
Old Feb 3, 2008 | 08:33 AM
Apocolips's Avatar
Apocolips
If you have to cut the cable to splice it, what is a good way to get a clean 90 degree cut? Every time I try and cut it using dikes it is more of a "crimpping" cut than a straight cut!
Old Feb 3, 2008 | 09:01 AM
Duke94's Avatar
Duke94
Remove the tail light lens (if that's the one that is dim)and clean up the small lens that is on the end of the fiber optic cable. You might have to do the same at the console end.
Here's the repair kit.
http://www.zip-products.com/Zip/prod...8F6F55D288337B
Old Feb 3, 2008 | 09:26 AM
wallifishrmn
Any recommendations of what's best to clean the fiber optic ends?
Old Feb 3, 2008 | 10:52 AM
StickShiftCorvette's Avatar
StickShiftCorvette
To get the best splice I make up an aluminum tube that will provide a press fit with the OD of the fiber optic cable. Shrink tube will not hold it rigidly enough to get the best light transmission.
Clearly clean ends are also critical....
Old Feb 3, 2008 | 11:03 AM
7T1vette's Avatar
7T1vette
Try the website below for inexpensive repair kit for Corvette fiber optics cable system:
http://www.watsons-streetworks.com/fiberoptic.html
Old Feb 3, 2008 | 05:48 PM
ENG40's Avatar
ENG40
Thanks again 71vette, thats a great link to the watsons site.
Old Feb 4, 2008 | 08:47 PM
rumblefish's Avatar
rumblefish
7th Gear
I just used a "fresh" razor blade, you are only cutting the individual cable. It might work to have someone watch the output at the console while you are doing the repair, move the optics around to otain max brightness and then crimp the tubing
Old Feb 5, 2008 | 02:39 PM
68/70Vette's Avatar
68/70Vette
Two of the fiberoptic cables going to my front headlights had been cut. During bodywork, someone probably thought they were electrical wires. I discovered this after I bought the car.
It was really annoying to me to be driving at night and see the two dead fiberoptic light indicators on the shifter console. So, I just stuck some the cut fiberoptic cable into a small section of rubber tubing, and then got a minilight bulb and stuck it in the other opening of the rubber tube. I then wired the minilight bulb in parallel with the headlamp. (I did this for both cut fiberoptic cables.) Now when I turned on the headlights, all my fiberoptic console indicators worked. Happinness. OK, it was a little fakey, but it looked good in the car.
I since replaced the entire front harness, including fiber optic cables. Everything is now factory correct. (Lectric Limited harness.)
Old Feb 5, 2008 | 03:16 PM
rdrunnur's Avatar
rdrunnur
Use De-natured Alcohol to clean the ends and a Lint Free cloth.
Rd
To Broken fiber optics
