Carriage Bolts
Old Feb 6, 2008 | 11:27 AM
stinger12's Avatar
stinger12
I found a site selling grade 5 ones, I'm not sure how expensive they are though.
http://www.advancefasteners.com/Inve...php?ProdID=AHK
Old Feb 6, 2008 | 02:02 PM
71rdster's Avatar
71rdster
Originally Posted by Duke94
Mcmaster-carr. The ones that you have are probably grade 5 not grade 8.
http://www.mcmaster.com/
Mcmaster-Carr will have a much better selection.
Old Feb 6, 2008 | 02:21 PM
stinger12's Avatar
stinger12
I would just like to mention one thing - not all bolts you get from vendors are high quality, I don't care what anyone says. I was tightening a new trailing arm bolt and the threads got stripped and the nut threads pulled out. I was using a brand new, just calibrated torque wrench and I had the shims and trailing arms wedged in the pocket like they are supposed to be. I have to replace the bolts now - I'm going to drill a hole in a long grade 8 bolt and use that with a castle nut instead. So, if you think just going to the vendors for bolts is good enough, think again. I buy all my colts from an industrial fastenal here in Calgary, grade 8 and plated. This is the main reason I brought up this subject - some of the vendors out there are charging a crap load of money for fasteners that are cheap quality.
Old Feb 6, 2008 | 02:28 PM
jnb5101's Avatar
jnb5101
i agree whole-heartedly.
but, as a word from the sunny south, do you think that the freezing cold, arctic, bone chilling, god awful, sub zero temperatures you have where you live weaken the bolts?
jeff
Old Feb 6, 2008 | 02:41 PM
stinger12's Avatar
stinger12
jeff
Not at all, because my vette is in a heated garage
Old Feb 6, 2008 | 02:54 PM
burners's Avatar
burners
Cruise-In IV Veteran
Cruise-In V Veteran
All those listed are coarse thread. Like others said fine thread has more contact area and, therefore, is stronger. Additionally, fully threaded fasteners are not as strong as partially threaded. Good points about junk fasteners from vendors. Keep an eye on what you are buying.
Old Feb 6, 2008 | 03:25 PM
stinger12's Avatar
stinger12
If you get a grade 5 carriage bolt with a really long shank that isn't threaded, you could use an appropriate sized fine thread die (from a tap and die set) and make the correct fine thread one...wouldn't take to long either. I've made my own bolts before and its really easy using a fine thread die...using a coarse thread die by hand takes for ever though because of how deep it cuts.
Old Feb 6, 2008 | 04:26 PM
LYLE's Avatar
LYLE
Anyone parting out a vett should have some for sale. A quick WTB ad should get a few hits I would think.
Old Feb 6, 2008 | 05:16 PM
stinger12's Avatar
stinger12
The problem is I don't like reusing old bolts. I've only reused two bolts on my resto so far and they were the massive ones on the front caliper bracket...the rest of my stuff is all grade 8 and plated.
Old Feb 7, 2008 | 09:17 AM
LYLE's Avatar
LYLE
The bolts on the gear box were well oiled as most power steering cars leaked so the bolts have little if any rust.
Old Feb 7, 2008 | 11:25 AM
stinger12's Avatar
stinger12
Mine were rusty as hell. I am going to call Fastenal later on today and see if they carry grade 8 carriage bolts...or if they know someone who does.
Old Feb 7, 2008 | 12:11 PM
S489's Avatar
S489
this is okay so long as you know (account for) that it is not as strong as a quality bolt from the mfg - all quality bolt/screw threads are rolled.
Old Feb 14, 2008 | 02:44 PM
  #33
stinger12's Avatar
stinger12
I just talked to Fastenal - the guy I talked to said that grade 8 carriage bolts are very uncommon and that he can get me grade 5 carriage bolts with fine threads instead of coarse. I will go home tonight and figure out what size I need and I will try and order the correct ones tomorrow - if they have what I need, I'll post the part number so everybody on the forum can get the correct ones.
