Carriage Bolts
Old Feb 5, 2008 | 01:42 PM
stinger12's Avatar
stinger12
Default Carriage Bolts
The steering box and steering idler uses carriage bolts to mount to the frame. There are also a couple of pieces in the front bumper support area which use carriage bolts. I knopw home depot sells them, but they are not grade 8 and are designed for wood. Where can I find grade 8 ones other than the corvette vendors who charge a fortune. Are the steering box bolt "squares" in the frame 3/8''?
Old Feb 5, 2008 | 02:14 PM
jnb5101's Avatar
jnb5101
other than specialty bolt and fastener shops in your area, try ace hardware(believe it or not !) or lowes home center. they both carry a good selection or #5 and #8 bolts. don't use those unmarked grade #2 bolts!!!!
jeff
Old Feb 5, 2008 | 02:21 PM
pws69's Avatar
pws69
I would try a Chevy/GM dealer.
Old Feb 5, 2008 | 03:11 PM
Duke94's Avatar
Duke94
Mcmaster-carr. The ones that you have are probably grade 5 not grade 8.
http://www.mcmaster.com/
Old Feb 5, 2008 | 03:12 PM
SeattleC5's Avatar
SeattleC5
I have found grade 8 rated bolts at Lowes Hardware before and used them on the car. In their fastener aisle they usually have a cabinet of automotive bolts and various fasteners. Good luck!
Old Feb 5, 2008 | 03:35 PM
LYLE's Avatar
LYLE
As I recall the originals may have been fine thread.
Old Feb 5, 2008 | 03:57 PM
burners's Avatar
burners
Cruise-In IV Veteran
Cruise-In V Veteran
The originals are, indeed, fine thread. You will have to check with a specialty fastener supplier. McMaster-carr doesn't carry them and neither will most hardware stores. I bet the reason the Corvette catalogs charge so much is because they have to have them made for them. It's not a common enough item to be off the shelf so it will cost a lot more.
Old Feb 5, 2008 | 05:10 PM
Alan 71's Avatar
Alan 71
I've had luck getting some unusual bolts at Fastenal Company. I'm not sure how wide spread they are, but they are on the Net.
Regards,
Alan
Old Feb 5, 2008 | 05:15 PM
Gordonm's Avatar
Gordonm
Regards,
Alan
Fastenal is everywhere. They are one of my distributers for our products. I can contact them tomorrow and ask about this. I am working their booth at Daytona this year and have a seminar for 300 people coming up soon. Any bolt question I can get the answer from them. I have 4 of them within a 20 mile radius of my house. Just look them up on the web, they have a locater tab so you can find them.
Old Feb 5, 2008 | 05:23 PM
stinger12's Avatar
stinger12
Stupid question, but what's the difference between fine thread and coarse thread (I know they have more threads per inch) other than building a stock NCRS car...does it really matter?
Old Feb 5, 2008 | 05:24 PM
dannyman's Avatar
dannyman
C.T.C.
GM Dealership
Fastenal
Brefasco (sp.?)
Not sure what other fastener places you have in Calgary.
More thread = more grip
Old Feb 5, 2008 | 05:25 PM
stinger12's Avatar
stinger12
I get all my fasteners for the vette from acklands grainger. They order them from Fastenal
Old Feb 5, 2008 | 05:26 PM
stinger12's Avatar
stinger12
Hmmmm, I've never heard that before.
Old Feb 5, 2008 | 07:40 PM
jnb5101's Avatar
jnb5101
i believe that the fine thread bolts have a larger amount of steel in the bolt-nut interface.
jeff
Old Feb 5, 2008 | 08:37 PM
bruced267's Avatar
bruced267
Yes I too agree more threads per inch = more grip so to speak. Plus the threads are FINE and there is more contact area! Try your local drive shaft shop (if there is a one) they have every bolt you can think of!
Old Feb 5, 2008 | 11:39 PM
Solid LT1's Avatar
Solid LT1
Steering box bolts are pretty unique, they are grade 5 or 8 not quite sure. I think GM discontinued them last year. Be careful using Lowes/Home Depot bolts most are Chinese JUNK! I don't care what they are rated at, you need to think about quality control and other issues. If you want a good book on hardware ante up $25 (since bolt failure can cause CRASHING!) and try: Carroll Smith's "Nuts, Bolts, Fasteners and Plumbing Handbook" WRITTEN BY A RACER FOR RACERS and car guys in general. Or you can keep "Bubbaing" your Vette like you presently are if you use those "discout wharehouse fasteners" in the wrong areas.
Here is a link to Amazon for the book: http://www.amazon.com/Fasteners-Plum...2272506&sr=1-2
Old Feb 5, 2008 | 11:46 PM
stinger12's Avatar
stinger12
I never use chinese fasteners on my vette, and I mean never. I buy all my stuff grade 8 from fastenal - they are even plated to prevent rusting. I was just curious as to where I can buy the carriage bolts cheaper than the corvette vendors, that's all.
To Carriage Bolts
Old Feb 6, 2008 | 12:17 AM
71406's Avatar
71406
The replacement bolts for by steering box that I purchased from Paragon were course thread not fine like the originals. I installed anyway as I couldn't locate any fine thread...and it was summer so I wanted to drive the car.
Old Feb 6, 2008 | 05:24 AM
Brewmeistergi's Avatar
Brewmeistergi
I've been looking for these bolts too. I got one at my "specialty bolt supplier" and it was threaded end to end. I decided I didn't want to use it. I went to Home Depot and bought one because the bolt shank was only threaded about a third of the way. This seemed stronger than threaded all the way. I mic'd the bolt and compared it to the original. The original was .370" at the shank, the Home Depot bolt was .330". Not close enough for me. I think this may be one of the things you've just got to swallow about during a rebuild. As stated before, this bolt is directly related to steering the vehicle ie: safety.
Old Feb 6, 2008 | 09:33 AM
SPIKESDAD's Avatar
SPIKESDAD
If You Have A Farm Implement Dealer Close Check With Them
Thet Use These Bolts Everywere.and Should Have Them In Grade 5 Or 8
