Engine Painting
Old Feb 6, 2008 | 07:40 PM
Brewmeistergi's Avatar
Brewmeistergi
Default Engine Painting
Is it advisable/desirable to use a primer on a block that's been baked (ie:down to bare cast iron) before applying the Chevy orange?
Old Feb 7, 2008 | 08:07 AM
Durango_Boy's Avatar
Durango_Boy
I use a self etching primer, but I still wire wheel and clean the block. The hot tanking can still leave a residue that dusts off.
Old Feb 7, 2008 | 08:28 AM
BarryK's Avatar
BarryK
when I painted the blocks out of my '65 and my '78 I used the hi-temp engine enamel paints from Hirschman Automotive. BTW, these are really nice paints! They specifically recommend NOT using a primer on the iron block as they claim their paint sticks better to the bare metal. I followed their instructions and so far after two years it still looks great.
I did use a primer on the steel oil pan though.
if interested, here is a link showing the painting, including the primer on the steel oil pan.
http://www.lbfun.com/Corvette/78Vette/mcu/parts.html
scroll about 3/4 the way down the page to get to where the painting pictures are.
Also, my suggestion is that you use multiple LIGHT coats of paint rather than few heavier coats. The first two coats of paint on my '78 block were very, very light, barely above a dry dusting on the block. The third and forth coats were more of a medium coating and the final fifth coat went on slightly heavier but still not very heavy at all.
Multiple thing coats tend to hold up better than heavier coats. Follow your selected paint's instructions for drying times between coats.
Old Feb 7, 2008 | 08:29 AM
FB007's Avatar
FB007
Old Feb 7, 2008 | 09:27 AM
lars's Avatar
lars
I use PPG's DP-series epoxy primers on all my engines before applying topcoat. It has proven to hold up extremely well over years of operation.
To Engine Painting
