Here's a stupid question
Old Feb 8, 2008 | 10:24 AM
a1sensei's Avatar
a1sensei
Default Here's a stupid question
I was wondering if an A.I.R. pump could be hooked up backwards to become a vacuum pump?
I am running a larger than stock cam, which lowers my vacuum. With my '81 Computer Command Control, I think sometimes the vacuum is lower than the computer likes. Years ago I took the smog pump off and put it into a box. I was wondering if I re-installed it, vented the pump output and fabricated tubing to hook up the pump intake to the intake manifold vacuum nipple if it might be a viable way to increase vacuum. What do you think? God bless, Sensei
Old Feb 8, 2008 | 01:04 PM
Durango_Boy's Avatar
Durango_Boy
It would probably help. I toyed with the idea of using an LT1 electric smog pump like that to suck air out of the system to help with vacuum but I never tried it. I ended up installing the Hydrobooster, and plan to go to fixed headlights.
