Pitman Arm question
Old Feb 8, 2008 | 07:06 PM
76yellow's Avatar
76yellow
Default Pitman Arm question
I putting power steering in a 68 convertable. It's a big block & i've got everything done from the ram to the pump & pulleys, etc. I don't have the body on yet ut everything seems to fit with no issues. I've seen pitman arms on e-bay. Some say for power steering. I used the arm that was on the car. Is this an issue ? Is there a difference between the 2 ?
Old Feb 8, 2008 | 08:35 PM
Aggitated Monkey's Avatar
Aggitated Monkey
Old Feb 9, 2008 | 08:19 AM
jnb5101's Avatar
jnb5101
the pitman arms for ps and manual are different. i think the ps arm drops down lower to clear the control valve.
jeff
Old Feb 9, 2008 | 04:02 PM
Willcox Corvette's Avatar
0Willcox Corvette
Former Vendor
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
The difference is the angle of the arm. We get this question over and over so we put this in the repair and help instructions on the site for you today. http://willcoxcorvette.com/repairand...lp.php?hID=182
Here is a picture of them.
Old Feb 9, 2008 | 09:59 PM
Kid Vette's Avatar
Kid Vette
These pics show the difference better. I can't remember who originally posted them.
Old Feb 10, 2008 | 11:10 AM
76yellow's Avatar
76yellow
Thanks for the info. I still don't know if I have to change it however. Everything seems to clear OK right now. I don't know what could change after I put the body on.
Old Feb 10, 2008 | 11:16 AM
76yellow's Avatar
76yellow
Thanks for the info. I suppose I should get the correct one although everything seems OK right now. I can turn it both directions & everything seems to clear.
Old Feb 21, 2008 | 11:21 PM
0Willcox Corvette
Former Vendor
Yellow,
You should change it. Using the non power arm puts the power steering control valve in stress. The valve works off the pressure from the inside of the valve in direct relation to the ball stud. The non power steering arm will put the ball stud in the wrong position and while it works fine now, it will cause early failure.
Willcox Inc.
Old Feb 22, 2008 | 09:58 PM
bobs77vet's Avatar
bobs77vet
From: Arlington Va Current ride 04 vert, previous vettes: 69 vert, 77 resto mod
i have a PS pittman arm from left over from my steeroids conversion and i believe i know where it is.....if you want it PM me. i'm sure we can figure out a suitable arrangement.....
Old Feb 23, 2008 | 07:46 AM
Jim Shea's Avatar
Jim Shea
The car assembly plants absolutely hated additional parts and part numbers on their assembly lines. And particularly two parts that looked so much alike.
Off-hand I do not know the reason for the two different arms that look so much alike. But there had to be a darn good reason that they couldn't make one of them work in both applications.
Use the correct one for your application.
Jim
Old Feb 23, 2008 | 11:03 PM
0Willcox Corvette
Former Vendor
Jim,
You are absolutely correct! If you look at a car without power steering and the position of the drag link, then compare it to the position of the power steering control valve stud you will see the difference.
While the non power pitman arm will work, it will put extra pressure on the valve stud and cause pre-mature failure.
Willcox Inc.
Old Feb 24, 2008 | 08:42 AM
silverslashstreak's Avatar
silverslashstreak
So that must mean that their is a different idler arm for power vs non power steer cars?
Last edited by silverslashstreak; Feb 24, 2008 at 08:44 AM. Reason: correct gramar
Old Feb 24, 2008 | 02:56 PM
0Willcox Corvette
Former Vendor
Yes that is correct!
To Pitman Arm question
