Mechanical or electric
I have a 2000 vortec motor, #10243880
Mortec say's: 350 ,95-00, 2 OR 4 Bolt main,Vortec truck,Gen-1 crate motors and zz4,roller cam,one piece rear seal.whew
So my questions are:
1: do i have a roller cam.
2: If i replace it,(looking for the lope of say a comp 268H),What cam should i use without having to mod anything,ie: grinding milling etc..
3:I was told there is no provision for a mech.pump.That there is no cam lobe to push a mech pump rod.yet there is a mech.opening.
I would like to use a mech.pump if possible,can I?
4: and lastly with my setup,can someone guess at the HP?
( holly 670,edelbock performer,of course vortec heads,stock exhaust),and what change in HP the cam/Headers will make?
wow,that's alot...I appreciate any info,I'm just trying to decide what direction i want to go.
If it is topped of with a carb then just make sure the cam has a fuel lobe and also get a fuel pump rod and mech fuel pump. However, if it is going to be Fuel injected a mechanical pump won't hold the pressure that an electric will so a Fuel injection system won't function properly.
As for the cam, if it will be a street motor I would say stay in the 230s of duration @ .050 lift to keep it street friendly but still give a bit of lope. Remember the more the duration the more the lopey idle but also the rougher the idle and the higher in the powerband all the power will be. Great for a track where you red line it, but terrible for a motor on the street that rarely sees above say... 4k or so RPM.
If it is a 2000 year model vortec engine that there is a 99.9% chance it is roller. (good base to start with)
Yes, you have a factory roller cam.
You can get a marine application cam for that motor, that will increase performance and won't break the bank or require changes to anything else.
Some of the Vortec engines do have the mechanical pump port bored, but some do not. Just look. If you can see the cam, you can use a mechanical pump and you just have to get a cam that has the lobe. If you can't see the cam, and it's just a dead end cast, then no, you have to use electric.
Hard to say, but with a Vortec engine, with stock rods and pistons and stock gasket thickness, you'll be looking at around 300 - 325 HP.
I am using an electric pump now,with the manual opening blocked off.
I guess i can use a mirror to peer into it, or maybe see inside it from below? Thats why i luv this forum,someone will know.
The ones I bought, however, were upgraded with lt4 springs so it's capable of up to .600 now
