slack in timing chain
Old Feb 19, 2008 | 04:48 PM
Ronaldo's Avatar
Ronaldo
Default slack in timing chain
Hi
I preparing an old cheap '73 350cui temperary engine. How much slack should there be in the timing chain, it feels a bit loose?
Old Feb 19, 2008 | 05:01 PM
76stingracer's Avatar
76stingracer
That is to much. Buy a new double roller chain and install. Very easy and inexpensive upgrade.
Old Feb 19, 2008 | 05:08 PM
burners's Avatar
burners
Cruise-In IV Veteran
Cruise-In V Veteran
That's pretty loose. Besides, it's the old nylon toothed gear. I would replace it with a cheap rebuilder set. It should only be about $20. That is cheap insurance. Are you in Denmark? Maybe it will be a little more for you but I still think it's worth it.
*edit* I see you are in Denmark, not Germany.
Old Feb 19, 2008 | 05:13 PM
Ronaldo's Avatar
Ronaldo
Thanks... I thought it was a bit too loose. I can get a new double roller chain at a local store in DK for 40 $. I think I will do that...
Old Feb 19, 2008 | 07:45 PM
Artsvette73's Avatar
Artsvette73
[QUOTE=burners;1564170870]That's pretty loose. Besides, it's the old nylon toothed gear. I would replace it with a cheap rebuilder set. It should only be about $20. That is cheap insurance. Are you in Denmark? Maybe it will be a little more for you but I still think it's worth it.
Cheap insurance. You are there now. You won't have to go back later
Old Feb 19, 2008 | 08:11 PM
RunningMan373's Avatar
RunningMan373
Time for a change,, check this out, what I just did, look at what that timing gear does. I used a Cloyes double roller with forged steel gears from summit. A good idea. Summit p/n CLO-9-3500TX9. Probalby a good idea to replace the Ballancer 'while your at it' the ballancer is a 6 3/4" for the L48, not an 8" as pictured btw, C.
http://forums.corvetteforum.com/show....php?t=1920169
For referance, heres the nice steel crank gear. LOOSE THE PLASTIC/ALUINUM POS CAM GEAR!!!
Old Feb 19, 2008 | 08:59 PM
pbcanney's Avatar
pbcanney
$20 to $50 is and easy way to SAVE $2000
believe this man!
real damage from one of those "quiet" albeit worn plastic coated gears
Old Feb 20, 2008 | 04:25 AM
Ronaldo's Avatar
Ronaldo
Im definately not going to keep that nylon gear.
will this be a suitable replacement?
http://www.firstmile.dk/product.asp?...sub=127&page=1
Old Feb 20, 2008 | 04:44 AM
RunningMan373
Excellant. double roller, double billet steel gears
Old Feb 20, 2008 | 05:01 AM
Ronaldo's Avatar
Ronaldo
Im going to order one of those then
Anything I should be aware of when I change it, or is it just bolt off, bolt on?
Old Feb 20, 2008 | 06:48 AM
1981Z06Vette's Avatar
1981Z06Vette
You may need a puller for the crank gear...other than that, its pretty straightforward with normal hand tools. You may want to use some locktite on the cam gear bolts, too! Oh, and if the engine has a groove worn on the end of the crank (it likely does), get a repair sleeve for it (available through Fel-Pro and others, though you may have to buy another timing cover gasket set to get it).
Old Feb 20, 2008 | 06:55 AM
FB007's Avatar
FB007
Huh?
Old Feb 20, 2008 | 09:55 AM
Jud Chapin's Avatar
Jud Chapin
St. Jude 15 Year Donor
St. Jude Donor '11 thru '25
I changed my original gears on my '76 a while back with about 90K miles on them and they actually looked pretty good. I remember I had a '69 Grand Prix, though, and the originals lasted about 65K which GM said was normal. It tore up but luckily didn't damage anything else. One of my other cars is a '91 Lincoln Mark VII with the 5.0. I've got 165K original miles on it and it runs like the day I bought it (new) and the Mark VII forum guys say they never change them unless they got it torn down to that point. No plastic teeth, I guess. Anyway, change 'em out and then you don't have to worry.
Old Feb 21, 2008 | 04:22 AM
RunningMan373
you'll need a gear puller like this, summit p/n WMR-W87123, 15 bucks
A 2 jaw would also work just fine.
Also need a harmonic ballancer puller/installer kit like this one to pull the h/b off and to put the crank gear and then the h/b on. Summit p/n PRO-66514. 70 bucks. You could get away without this one, and use a wide steering wheel puller to pull the h/b, and use a cut piece of steel pipe and the crank bolt to put the crank gear and then the h/b on, but I would recomend the tool kit, if it's in your budget.
Originally Posted by FB007
Huh?
You'll need a timing chain cover gasket set, which should also include a new crank oil seal. Use the new one, and be sure to put assembly lube on it's contact surface when you put the timing cover back on, New crank oil seal installed in it. summint p/n FEL-TCS45165
Take your time and use some care, you should be fine. That's all the special tools needed, get some rtv, you might want to replace the harmonic ballancer and water pump while thier out. I recently completed this job with the help of the Forum, it takes a while (8 hours relisticly) but isn't that hard.
Good luck,, C.
Old Feb 21, 2008 | 07:52 AM
Ronaldo's Avatar
Ronaldo
I already got a complete felpro smallblock gasket set, a heavy duty 2 jaw puller, new waterpumpe, new harmonic balancer.
So it looks like I only need the H/B puller/installer. I would not hesitate to buy one if only I didnt have to order it from US. Expensive shipment + a lot of taxes = 180$ when it gets here.
Thanks for all the help
Old Feb 22, 2008 | 01:48 AM
RunningMan373
A hammer and a block of wood can be used also,, check out a haynes manual, I think they list some alternate methodes. C.
Old Feb 22, 2008 | 07:28 AM
BKbroiler's Avatar
BKbroiler
I would line up the timing marks on the two sprockets before I removed them just to be safe. (Cam sprocket at 6 o'clock and crankshaft sprocket at 12 o'clock).
Old Feb 22, 2008 | 10:22 AM
Artsvette73
Never use a block of wood and hammer to install the balancer. You will destroy the thrust bearing on the crank shaft.
A jaw puller should not be used. As you could separate the outer ring of the balancer from the hub. The correct method is using a puller that bolts to the three pulley mounting bolt holes. To install it you want the tool to press it back on.
Old Feb 22, 2008 | 07:56 PM
RunningMan373
I Serously douht a block of wood and hammer would dammage the thrust bearing, that being said, it's not the recommended methode, but it is in the Haynes manual. C.
To slack in timing chain
