Spherical T/A Arm bushings
Old Feb 22, 2008 | 12:55 PM
frank24's Avatar
frank24
Default Spherical T/A Arm bushings
Not happy w rubber/poly.
Anyone ever use spherical bushings in your trailing arms??
If so, where did you get them and did you alter the factory t arm?
Old Feb 22, 2008 | 02:00 PM
Belgian1979vette's Avatar
Belgian1979vette
As far as I know of only VSE had them (Herb Adams). They were distributed by Moroso, but not anymore. They can't be had anymore unfortunatly.
Old Feb 22, 2008 | 02:26 PM
1mpalss's Avatar
1mpalss
Default Johnny Joints as an alternative?
Maybe try Twin Turbo's solution and use the Johnny Joints?
http://forums.corvetteforum.com/show...ghlight=johnny
Or this thread, page 3
I wonder what the benefit of the spherical/Johnny joint would have on your ability to control toe a little better, particularly if you adapt a 6 link to the setup?
Old Feb 22, 2008 | 02:35 PM
Belgian1979vette
not much, the toe problem is mainly design related.
Old Feb 22, 2008 | 02:52 PM
1mpalss's Avatar
1mpalss
I wonder what this setup looks like when modeled like FLEXUSMARK did in this post:
http://forums.corvetteforum.com/show...light=6+lin k
I wonder if we can manipulate our rear toe without adding dual control arms like a C4? Maybe:
raise the differential .5 to 1 inch in the chassis, lower the stock lower control arm mount .5 to 1.5 inches or so (with a spacer block or Smart Struts), add Norval's upper camber rod and remove the c-clips (like the 6 link), replace the front trailing arm bushings with spherical or Johnny Joints (instead of having to construct and mount new trailing arms), and then build some sort of toe-control rod (like Stroker). It would combine better geometry (from the Chevy Power Manual) with the precise camber control of the 6 link (eliminating the half shafts from their suspension duties) and real toe control from a toe rod (aided by the Johnny Joints' better articulation). I think FLEXUSMARKS' plans nearly eliminated the in and out movement of the halfshafts, making specially contructed slip-joints unnecessary. Heck, add an outer half-shaft safety loop and you'd be legal to run faster on NHRA drag strips. I just don't have the engineering/CAD expertise to determine if this could give some degree of toe control without binding up. It certainly couldn't eliminate toe change, unless you could also hinge the hub area of the trailing arm - then a toe rod, or dual lower strut rods, would offer real toe control.
I've only been thinking of this type of arrangement to simplify an improved C3 rear suspension and, possibly, keep it legal for most racing sanctioning bodies.
Old Feb 22, 2008 | 03:22 PM
Scott Marzahl's Avatar
Scott Marzahl
Guldstrand has probably what you are after, most of this stuff is designed for track cars though. Use the toe adjusting rods and the metal trailing arm bushings, bottom of page, center.
http://www.guldstrand.com/scripts/pr...?idCategory=41
Old Feb 22, 2008 | 04:30 PM
73339's Avatar
73339
I would not recommend those on the street or anything that gets driven a lot.
Redvetracr said they get sloppy after awhile
Old Feb 22, 2008 | 05:06 PM
Lightweight 001's Avatar
Lightweight 001
We build them and they will soon be on the website. They sell for $250 powdercoated per side. If you have any questions please call me at Duntov Motor Company 972-243-3838.
Edward
Old Feb 22, 2008 | 06:26 PM
TheSkunkWorks's Avatar
TheSkunkWorks
From: Graceland in a Not Correctly Restored Stingray
Edward
Mind sharing here with what type bushing/bearing? Johnny's??
Old Apr 25, 2010 | 03:24 AM
1mpalss's Avatar
1mpalss
Default Started installing Johnny Joints in my '70
Well, here goes. Cut out the old rubber bushings with a plasma cutter:
The Johnny joints are 2" from Currie Enterprise and the sleeve has to be welded into the arm. Silver tube was added to mount a grease zerk that would be accessible when arms are installed:
I'm obviously not a welder by trade. Gas Millermatic makes it about as easy as it gets though:
That's all I've got for now. These Johnny joints should give a little better control than rubber without going all-out with spherical bearings.
Old Apr 28, 2010 | 10:08 PM
TODD C's Avatar
TODD C
a company called Global West Performance sells trailing arms with spherical bearings. they are a little bit pricey, but look to be very well constructed from the pictures on their website.
Old Oct 18, 2020 | 10:39 PM
Dagious's Avatar
Dagious
Has anyone found and installed spherical bearings in the standard Trailing Arms? If so, by who and what is the size.
Old Oct 18, 2020 | 10:44 PM
Metalhead140's Avatar
Metalhead140
C3 of Year Finalist (track prepared) 2019
I'm using the Global West arms with spherical joints and apart from needing to shorten the handbrake cable, they work great and are super solidly built.
Old Oct 28, 2020 | 09:38 AM
Dagious's Avatar
Dagious
Which cable did you shorten? The front cable or the rear that hooks up to the drums? I’ve read that with the relocation of the cable mounts to the inside, there is an issue.
Old Oct 28, 2020 | 10:06 AM
reno stallion's Avatar
reno stallion
C2 of Year Finalist (appearance mods) 2019
Took my Van Steel offset TAs cut out the poly ends and put in johnnys
Old Oct 28, 2020 | 12:37 PM
lionelhutz's Avatar
lionelhutz
From the post 2 above where yours was posted are pictures of the work and this info - Johnny joints are 2" from Currie Enterprise
Old Oct 28, 2020 | 02:02 PM
reno stallion
I got mine from Currie
Old Oct 29, 2020 | 07:38 PM
Metalhead140
The rear cable. For now I've just cut it and used cable clamps, and that has worked fine.
Old Oct 29, 2020 | 10:57 PM
73C34me's Avatar
73C34me
I used a hole saw and removed the bushing area of the t-arms and welded in jonnie joints. Pretty straight forward.
To Spherical T/A Arm bushings
