Lower body or raise diff?
Old Oct 29, 2020 | 02:37 PM
ChrisLSx's Avatar
ChrisLSx
Default Lower body or raise diff?
1979 Coupe - frame is getting a full weld/gusset job and I'll be installing a 6 point roll bar.
I'm replacing the rubber body mounts with aluminum. The aluminum mounts are 68-72 replacements and are about 1/2 the thickness of the rubber bushings. As such, the body is going do be "lower" than it was with the 79 rubber bushings. However, I'm also going to be solid mounting the rear diff and therefore have the option to raise the diff (I may even convert to the later aluminum batwing mount).
Am I better:
  • Using the 68-72 bushings, letting the body come "down" and limiting the amount the diff rises?
  • Machining new (thicker) bushings, keeping the body "up" and letting the diff come up more?
Old Oct 29, 2020 | 08:25 PM
Metalhead140's Avatar
Metalhead140
C3 of Year Finalist (track prepared) 2019
Are you also lowering the suspension (ie using a longer bolt or whatever)? If so, then raising the diff will improve the rear suspension geometry, particularly toe change in bump. If you're not planning to lower the suspension then there's not really a gain in raising the diff. Personally, I'd lean towards doing both and then lowering the suspension less, butthat assumes that you're looking to lower the car a reasonable amount - it depends on how much you want to lower the car overall and what your aims/goals are.
Old Oct 29, 2020 | 10:59 PM
ChrisLSx's Avatar
ChrisLSx
Some, but I haven't sorted out how much yet. I'm about to pull the frame out from under the body, sand blast it and then seam weld it. I want to make my modifications before I have the frame powder coated, so I'm trying to think ahead.
Old Oct 30, 2020 | 12:32 AM
ignatz's Avatar
ignatz
From your member name, sounds like you have an LS motor. Have you determined how your driveshaft geometry is changing?
Old Oct 30, 2020 | 12:39 AM
ChrisLSx's Avatar
ChrisLSx
No LS in this car. Over the past 20 years I've had a half dozen different vehicles (currently have a C5) with LS motors, but I'm going different (for me) with this 79. It's currently got the factory L48 and automatic, but that's being replaced with a 496 and a T56.
To Lower body or raise diff?
