Tires...
Old Dec 5, 2001 | 04:07 PM
spiru's Avatar
spiru
Default Tires...
I have Firestone Firehawks on my 78 Vette now, but I'm wondering what kind of tires other vette owners use. I thinking of switching to a lower profile tire this spring and looking for some suggestions for a replacement.
Old Dec 5, 2001 | 04:11 PM
mulchie's Avatar
mulchie
Default Re: Tires... (spiru)
BF Goodrich Radial T/A's. Either 245/60 or 255/60 depending on your taste. Pretty good value compared to Goodyear's. 255's should work on the 78 without rubbing.
Old Dec 5, 2001 | 04:41 PM
im181owner's Avatar
im181owner
I have BF Goodrich Radial T/A's. Either 255/60 on my 81.
Old Dec 5, 2001 | 05:03 PM
Jvette73's Avatar
Jvette73
Default Re: Tires... (im181owner)
I use BFG Comp TA VR4 235/60-15 26.1" in diameter. A bit lower profile than stock. V-rated @ 149mph. Only come in blackwall though. These tires do good for me on street and track.
Old Dec 5, 2001 | 08:28 PM
mrbeaubo's Avatar
mrbeaubo
Default Re: Tires... (Jvette73)
I use BFGoodrich Radial T/A's 255/60-15 all the way around, had slight rubbing problems and had to trim the fender back a little bit.
Old Dec 5, 2001 | 10:15 PM
79er's Avatar
79er
Default Re: Tires... (mrbeaubo)
Bridgestone Pontenza's re730 in 255/50/17 on all four.
Old Dec 6, 2001 | 12:32 AM
redc3vette1's Avatar
redc3vette1
BFG RADIAL T/A'S I run 275/60's out back and a lil different up front and during race time i run some 28-12.50-15 Mickey Thompson ET Streets but for your money and every day driving its hard to beat the BFG'S :cheers: :cheers:
Old Dec 6, 2001 | 01:04 AM
VETDRMS's Avatar
VETDRMS
Dunlop SP SPORT 8000's, 245/50/15, been VERY happy with these tires, perform AWESOME. I'm getting Nitto 555 next 245/40/17's :)
Old Dec 6, 2001 | 01:36 AM
Chris Fowler's Avatar
Chris Fowler
Cruise-In IV Veteran
St. Jude Donor '03-'10
BFG Radial T/A's here too. 255/60R15 all around
Old Dec 6, 2001 | 08:00 AM
MARKUS_P's Avatar
MARKUS_P
Default Re: Tires... (VETDRMS)
245/50/15 !! this is a very small tire :eek:
Some say that 265/50/15 looks too small on a vette and doesn´t fill the fender well.
Would be interested in a picture of your car, hmmm maybe you´ve a homepage
Old Dec 6, 2001 | 08:41 AM
norvalwilhelm's Avatar
norvalwilhelm
I have 265-50-15 on the front with 3 1/2 offset rims without any problems and 305-50-15 BFG TA radials on the back. The back required knotched trailing arms and a slight modification of the fender lip. Cutting it back to half it's original thickness. Fills out the wheel well.
I picked up new 305s this fall for $85 CDN each.
Old Dec 6, 2001 | 06:32 PM
Cajun99's Avatar
Cajun99
I have 225-70-R15 Comp TAs on mine now but when I replace them I'm going with 245-60-R15 Comp TAs.
I had 255-60-R15 Comp TAs on my '78 Pace Car and the wheel wells were cut at the factory. I don't think I can fit those under the front of my '75 and I don't want to cut the wells down.
Old Dec 6, 2001 | 06:50 PM
Green 79's Avatar
Green 79
Default Re: Tires... (Cajun75)
I have BFG/TA 255/60/15's all the way around. I just have to watch out when I turn all the way to lock. Rubs a little bit.
Old Dec 6, 2001 | 11:19 PM
MikeE.79's Avatar
MikeE.79
I have a new set of goodyear eagle II tires on my 79 and like them so far but have heard alot of people grumbling that they're not as good as they used to be.
Old Dec 6, 2001 | 11:26 PM
MotorHead's Avatar
MotorHead
From: Who says "Nothing is impossible" ? I've been doing nothing for years.
Default Re: Tires... (MikeE.79)
BFG 295 50's on the back and 265 50's on the front, BFG says the 50 series
has a stiffer sidewall than the 60 series, different compounds used :D
Old Dec 6, 2001 | 11:39 PM
Dave68's Avatar
Dave68
This man knows his tires!
To Tires...
