rev limiter
Old Feb 25, 2008 | 06:05 PM
vett 68's Avatar
vett 68
Default rev limiter
what is the best just rev limiter to put in a 68 with 383 with stock ignation
Old Feb 25, 2008 | 06:19 PM
TheSkunkWorks's Avatar
TheSkunkWorks
From: Graceland in a Not Correctly Restored Stingray
IMHO, I'd just replace the dizzy with an MSD Digital E-Curve unit, which includes a rev limiting function, and consider an MSD-6 series box as an optional add on.
Old Feb 25, 2008 | 06:21 PM
Scott Marzahl's Avatar
Scott Marzahl
The old standard is the MSD 6AL, Summit has a new house brand out for less, SUM-850600 no idea if it's any good or not.
Old Feb 25, 2008 | 07:22 PM
Gordonm's Avatar
Gordonm
I ran a Crane HI6 box with my stock Distributer for a couple of years. The points just trigger the box. It is a digital box and has rotary dials for the rev limiter. I have bounced it off the limiter many times. I once set it at 4000 rpm just to see how good it worked. I stood on it in 2nd gear and just left it there. It never went over 4000 rpm. I still use the Crane box but I have a MSD dist. now. Still use the Crane box for a limiter.
Old Feb 25, 2008 | 08:12 PM
OzzyTom's Avatar
OzzyTom
Is there a module that can be added to an HEI distributor to give rpm limit control? I have a mechanical tach drive HEI dizzy (from Mid-America) on the new stroker, and shudder at the thought of not having any limit control other than valve bounce.....
http://www.mamotorworks.com/corvette?frame=4.1166
Old Feb 25, 2008 | 10:30 PM
JustinD's Avatar
JustinD
I have the e-curve with a 6a box. The E-curve is great just get it to have the timing always be at 20 or 25 fire it up set you timing at idle to what you want your total to be and then set the distributor to the curve you want and your done with your timing. It is always there and you can have the advance come in sooner or later on different curves depending on your setup. It will not let you go past your set rev limiter it just makes a noise you will never forget if you have a throaty exhaust system. Never really knew how much I would go over it until I got the dizzy. When your tires are spinning the revs go up fast.
Old Feb 25, 2008 | 10:41 PM
gkull's Avatar
gkull
The Crane digital
Old Feb 26, 2008 | 12:37 AM
TimAT's Avatar
TimAT
That was close!! My first thought was to just install a cheapo set of points- guaranteed to bounce like crazy- limits revs real well.
gkull is correct- a DIGITAL rev limiter is the only way to go.
Old Feb 26, 2008 | 08:52 AM
GrandSportC3's Avatar
GrandSportC3
Cruise-In IV-V-VI-VII-VIII Veteran
St. Jude Donor '03, '06, '17
If you want to save some bucks and don't mind having chinese stuff on your car, go with this one:
http://cgi.ebay.com/ebaymotors/PROCO...spagenameZWDVW
I know people using it and they had no issues with it so far..
I personally use the MSD 6AL on my race car.. I used a ProComp distributor (HEI) when I had my old 406 engine dynoed (after I rebuilt it) and it worked flawless..
Old Feb 26, 2008 | 09:15 AM
DRIVESHAFT's Avatar
DRIVESHAFT
MSD makes a replacemwnt module for that
http://store.summitracing.com/partde...5&autoview=sku
Old Feb 26, 2008 | 09:48 AM
stingr69's Avatar
stingr69
I use a Crane HI-6 multispark CD with the stock HP points and stock coil used as a trigger on my 69 Camaro. This setup does not misfire to well over the self imposed 7200 RPM red line I have it set at. The points do not carry the load when used in this manner so they will last a long time and no need to set any dwell angle with them set up this way. The box takes care of that for you. I have the box mounted hiden up uder the dash so it does not show. Works great.
This is also good for a "Valet" setting on the rev limiter. You can set it with a small screwdriver for say 3000 RPM and it will not go any higher. Good for when your car is at the body shop for an extended stay or for when your son wants to take it to the prom etc.
-Mark.
Old Feb 26, 2008 | 10:05 AM
11Jake's Avatar
11Jake
Originally Posted by gkull
The Crane digital
Same here!
Old Feb 26, 2008 | 02:32 PM
enkeivette's Avatar
enkeivette
I'm running the MSD billet HEI. It has a built in adjustable rev limiter... if you're willing to go HEI.
Old Feb 26, 2008 | 03:41 PM
tsw71's Avatar
tsw71
MSD soft touch rev limiter. I've been running one with my Unilite for years. Will work with your points too.
Old Feb 26, 2008 | 04:06 PM
tshort's Avatar
tshort
CI 7-8 Veteran
I'll also add a recommendation for the Crane HI-6. I prefer it to the MSD that is comparably priced because the Crane has an adjustable dial for the rev limiter and the MSD has pills you have to switch out.
To rev limiter
