Slow drain
Old Feb 28, 2008 | 08:16 PM
kansas123's Avatar
kansas123
Default Slow drain
I have a dead battery after the car sits about 3 days after driving it. However, if I disconnect the battery, it holds it's charge and will start the car after more days than that. Is there a simple way to tell if something or which something is draining the battery? I have one of those cheap digital meters but don't know how to use it, could I touch the pos and neg of the battery with this device with the car off and see if the battery is being drained? Electrical just ain't my bag...
Thanks in advance........
Old Feb 28, 2008 | 08:27 PM
DvBoard's Avatar
DvBoard
IIRC:
Get a test light
Unhook the negative terminal
Place test light between terminal and negative battery cable
If light is on you have a draw
Check door switches/Pull fuses till you find what makes the test light go out
Durango_Boy's Avatar
Durango_Boy
Here, read this paper that a fellow forum member wrote. It outlines a VERY easy way to track down a drain on your battery.
http://photos.imageevent.com/durango...%20Testing.pdf
Old Feb 28, 2008 | 08:32 PM
Saint's Shark's Avatar
Saint's Shark
I feel your pain. My 79 has a serious draw that I'm getting closer to finding using the method DB replied with. My battery is drained within a day if I leave it connected. I've narrowed it down to one of the relays - the fuses don't appear to be the cause.
Old Feb 28, 2008 | 09:09 PM
7T1vette's Avatar
7T1vette
The fuses are NEVER the cause. You just pull the fuses...one at a time...until the "drain" goes away. Your problem will be somewhere in the circuit on that fuse.
Old Feb 28, 2008 | 09:27 PM
ptroxx's Avatar
ptroxx
From: Henderson Nv-Rohnert Park/Sonoma C o. ca/born in NY Rockaway Beach.
I must say that I just got over a battery drain.. I used the paper that Durango boy posted and it helped me very much.. I had nevery used a meter or a test light in that way before and now I fixed my problem.....
So follow that paper and ask questions....
I pulled every fuse till i found the right one.. then i messed with everthing that was on that fuse curcuit, pulled every relay and everything till I found what turned out my light..... It turned out to be my radio hooked up wrong...........'
If you need your wire diagram a forum member here on the c3 has the disc and can send your the diagram for your year if you ask....
Good luck
Old Feb 28, 2008 | 09:31 PM
kansas123's Avatar
kansas123
Default Fantastic
Fantastic, I will give it a go this weekend, my thanks to you all.
Old Feb 28, 2008 | 11:49 PM
marshrat99's Avatar
marshrat99
i had the same problem on my 79 and eventually just gave up and install a battery disconnect switch. A bit of a PITA but I'm enough of a Bubba to endure.
Old Feb 28, 2008 | 11:51 PM
ptroxx's Avatar
ptroxx
I also added a battery disconnect.. But I think I found mine...
Now I have an extra security system...
Old Feb 29, 2008 | 09:55 PM
CCrane65's Avatar
CCrane65
David, I have the same problem but it takes about 4 days to drain my battery. For the time being I keep a battery tender on it.
Tonight, I went through Durango_boys test procedure and apparently my drain is in a non-fused circuit.
The only ones I can think of are starter and alternator. I will disconnect the alternator and see if the light goes out but if it's not that, can anyone tell me what to look for next?
cc
Old Feb 29, 2008 | 10:19 PM
Hammerhead Fred's Avatar
Hammerhead Fred
cc
I had the exact same experience. Battery would drain down over a couple of weeks. Fuses did not indicate a fused circuit.
Disconnected the Alternator and "viola" drain be gone.
Tore down the alternator and found that I had a diode leak.
Simply replaced the diodes and problem solved.
Test light works but in my opinion a multi meter or milliamp meter is better at identifying such a small drain. You gotta be down in the 3mA range to observe it as the light just won't glow at that point. Just put the meter across the test lamp between the battery and battery cable.
Old Feb 29, 2008 | 10:59 PM
CCrane65's Avatar
CCrane65
Well, I disconnected the battery lead from the alternator and the light still lit. In fact, I noticed that it was pulsating. Almost like a heartbeat.
Old Mar 1, 2008 | 10:12 AM
CCrane65's Avatar
CCrane65
Well, crap. I forgot about the main power lead for the radio! I'll bet that is what is draining the battery.
I'll have to test again.
cc
I disconnected the main power feed for the radio and retested. Still there.
Old Mar 1, 2008 | 05:54 PM
kansas123's Avatar
kansas123
This is driving me nuts because although I have only had the car a couple of years, it never did this before and I do not know of anything that has changed in all this time. I have not had a chance to use the test light on it but will try to get to it tomorrow. oh wait, I did have some fuseable links blow and were replaced, along with some taping of wires to prevent shorts again. I will see....thanks for everyone's input.
Old Mar 1, 2008 | 09:56 PM
SIXFOOTER's Avatar
SIXFOOTER
The CTSY light circuit has a bunch of stuff on it that can cause problems. If however you pull that fuse and you still have the test light lit, it may not be the problem. Remove the fuses one at a time like mentioned, but don't put them back in until you have verified all the circuits, you could have more than 1 problem. The interior light times is fused from 2 different fuses: CTSY and Gauges.
The Key/Seat Belt Buzzer is electronic and fused from CTSY and Gauges, if it shorts internally it will cause a drain.
Sometimes the wires get connected to the starter incorrectly, there is a black wire down there with a large ring terminal on it. SOmetimes it gets connected to the Battery cable on the solenoid, it is actually a ground for the engine bay wire harness and should be connected to a bolt on the bellhousing.
The retractable antenna can hang up and stay hot sometimes too.
Old Mar 2, 2008 | 08:10 PM
CCrane65's Avatar
CCrane65
Well, I pulled every fuse in the fuse panel and the test light still lights up.
I guess I can pull the fuse in the horn circuit and see if the drain is there.
I also checked the black starter wire with the ring on the end and it is bolted to the bell housing on the back side.
Any other things I can check?
BTW, David, if you want to bring your Corvette over and put it up on the rack to check your starter wire you are more than welcome to.
I'd be glad to run through the fuses with you too.
cc
Old Mar 2, 2008 | 09:11 PM
Durango_Boy
Not just the battery lead, the plug too.
To Slow drain
Old Mar 2, 2008 | 09:17 PM
CCrane65's Avatar
CCrane65
Yep, the plug was out too.
cc
Old Mar 2, 2008 | 09:24 PM
den(thevetteman)78's Avatar
den(thevetteman)78
I had a power leak in my headlight swicht. If i turned the swicht off with the instrument panel light on, a week after i had no power but if i turn the instrument panel light off and then turn off my headlight i had no problems of power leak.
Old Mar 3, 2008 | 12:22 PM
kansas123's Avatar
kansas123
cc
Thanks CC! I will give you a buzz when the weather and time permits.
