bought stroker kit,is this normal
Old Feb 29, 2008 | 08:52 PM
Billysvette's Avatar
Billysvette
Default bought stroker kit,is this normal
The kit is suppose to be already balanced and clearenced,All of my connecting rods are ground down on top of one of the connecting rod bolts,i guess its the side that goes towards the cam.Is this normal or right ,this is my first stroker.The kit is from eagle.It just bothers me that this has been done,not use to this
Old Feb 29, 2008 | 09:04 PM
Scott Marzahl's Avatar
Scott Marzahl
Grinding a little off of the rod bolt head is common to gain some clearance, I take it these are a conventional stock rod and not a cap screw rod.
Old Feb 29, 2008 | 09:16 PM
Billysvette
The rods are i beam type rods ,suppose to be stronger then stock rods ,sir bushed ,arp bolts. They ground down a little bit into the rod its self right where the top of the connecting rod touches the rod.
Old Feb 29, 2008 | 09:34 PM
Scott Marzahl
As long as they just ground a little into the "boss" area around the head of the bolt and not into the beam it sounds like you are fine.
Old Feb 29, 2008 | 10:09 PM
MotorHead's Avatar
MotorHead
From: Who says "Nothing is impossible" ? I've been doing nothing for years.
I had to grind those rods before on the shoulder, it should not get into the shaft of the rod, can you take a pic ?
Old Feb 29, 2008 | 10:16 PM
682XLR8's Avatar
682XLR8
I've had to grind that part of the rod also, for cam clearance
Old Feb 29, 2008 | 10:20 PM
SanDiegoPaul's Avatar
SanDiegoPaul
From: San Diego - Deep Within The State of CONFUSION!
Yep. Normal.
Old Mar 1, 2008 | 11:12 AM
Billysvette
Thanks so much,the grinding does not get into the ibeam section,just the bolt collar.It had me worried
To bought stroker kit,is this normal
