72 rebuild
Old Mar 1, 2008 | 07:55 PM
tgensel's Avatar
tgensel
Default 72 rebuild
Started my engine on the run stand today and realized the water pump
is making a lot of noise! The numbers on the pump are 330 818 and D182. Two questions Is this the original pump and if it is does anyone make a rebuild kit for it?
thanks
Old Mar 1, 2008 | 08:53 PM
Glass Act's Avatar
Glass Act
From: 406ci SB, AFR 180 Heads - 490 HP @5,600 RPM 529 lb-ft @ 4,100 RPM
Can't say if it's original but after 36 years chance's are slim, but it might. No rebuild kit, just go buy a new pump and gasket.
Old Mar 2, 2008 | 12:53 PM
Alan 71's Avatar
Alan 71
If you want to keep your original pump there is a fellow in New York (and some others) who rebuild original pumps. It depends how important originality is to you. I used him ,but I'm very, very sick, in a good way. Arthur Gould.
Regards,
Alan
Old Mar 2, 2008 | 02:33 PM
tgensel's Avatar
tgensel
No sense rebuilding it if its not original thats why I'm trying to figure out if its original.
Old Mar 2, 2008 | 04:29 PM
easyasone2three's Avatar
easyasone2three
Corvette Restoration Guide says 1978-1982 water pumps have casting no. 330818. The D182 is the date code with A being January and B February and so on. The second character is one or two numbers denoting the day and this is followed by a single number denoting the year.
Also according to this book: All 71 and 72 sb's assembled through the end of May 1972 use casting no. 3991399. SB's assembled after May 1972 use casting no. 330813.
Be sure that it is 330818 and not 330813. I am thinking that the D182 is April 1, 1982 but I guess it could be April 18, 1972 if you have 330813. If it is 330813 I think that it could be the original.
Old Mar 2, 2008 | 08:03 PM
tgensel's Avatar
tgensel
thanks , It looks like it could be 330813 but I'm not sure.
Anyone use the rebuild kit from corvette central for water pumps?
Old Mar 2, 2008 | 08:17 PM
CORVETTEKARL's Avatar
CORVETTEKARL
I've use Kanter in Boonton, NJ to rebuild mine. They did it right and gave me a lifetime warranty. Don't recall the price they charged, but I remember that it was very reasonable.
Old Mar 2, 2008 | 10:23 PM
724544SPD's Avatar
724544SPD
I had Arthur Gould rebuild the pump on my 72 at the recommendation of several Forum members. It turned out real nice and for about the same cost as an off the shelf rebuilt pump. Check them out first.
Old Dec 8, 2023 | 05:35 PM
enul's Avatar
enul
If you still have that old water pump I'll buy it off you...
Old Dec 8, 2023 | 07:49 PM
Mooser's Avatar
Mooser
Thread was from 2008 and He hasn't been on here for 10 years, chances are he won't answer you. Post a WTB in the parts section and see if someone has what you're after
M
To 72 rebuild
