How did you solve your pinging problem?
Short history: Original 11:1, 350 hp engine; rebuilt in 2006: bored .030 over, same qjet carb and dist, new identically specd camshaft from GM... I realize my compression is more than 11:1 now, with the 30-over bore. How much more, I don't know.
I run only Sunoco 93, or BP 93 or Shell. I started using Max Lead 2000, which has improved the power and helped with the pinging, but it still pings under heavy load. It doesn't seem to matter what rpm range. When you bury your foot in the pedal, you get pinging. The secondaries hardly even get time to open, before you hear it, and have to lay off...
Here's what I've done to-date:
- Had Lars rebuild distributor and carb in 2006
- tried to tune it using Lars' paper
- experimented with different springs on advance
- bought an adjustable vacuum advance
- used Max Lead 2000 (Tetraethyl lead additive)
- experimented with running with vac advance disconnected
- experimented with different total timing
- currently at 30 deg total timing
The only thing left I am going to try is, to block the heat crossover in the intake manifold, using the little blocker plates that come with the gasket set. I will try this within the next 2 weeks.
I'm just about done trying to tune this myself. I may end up taking it to one of two Corvette shops in MD and see if they can help.
If you solved your pinging issue, I'd like to hear what you did. Thanks -
before i started spending 40 bucks for a couple gallons of 110, i dumped a bottle of seafoam down the carb. as soon as i was finished, the car was done pinging and it had stopped dieseling, something that it had done with out fail ever every time i turned the car off for the last year.
now i have a nice holey double pumper on it, run at 36*, use 93 octane, and can floor it going up steep hills all day long and theres no pinging.
just noticed you said the motor was freshly rebuilt. never mind what i had to say, this was on a 65k 40 year old motor.
of course with our motor being over 11:1, thats probably getting well past the point of being able to run 93.
Lean mix (wrong ecu set up)
Overheat
worn distributor
wrong timing
I've cured overheat with a larger alu radiator and a scoop on the hood (and on top of this also an oil cooler...)
I've change the dizzi.
I've tuned a tornado ecu by a specialist.
Timing: it is a key iussue, i dont trust the timing set up with the strobo pistol, the only way is manual...once you've taken care of all other iussues that eventually could contribute to create a pinging situation you set your timing to a standard figure then you warm up the engine and run the car...if it pings then you retard it moving the dist backwards...until it doesnt, when it doesnt then you advance it just a mm...until it does again under full load, then you go back just a bit and you're done.
Bad quality fuels (specially on a 11. comp engine) and a lean mix could cause pinging too, but i guess you've worked out these iussues already.
While you are pulling the intake, I would suggest using a head gasket that gave you .030 to .040 quench. With the compression you're running now, your squish needs to be close to .030. Hope this helps.
I'm using the steel-type gaskets. So you're suggesting I use a head gasket that has a bigger cylinder diameter (ie .030 bigger), or is it .030 thicker? Thanks!
No, your quench distance is measured from your piston top to head, or head gasket thickness. The smaller this distance is, (up to a point), the less chance you'll have detonation (ping). The smaller distance promotes intake charge swirl, creating a better burn. Lots of info on quench, google it. I'm confident it'll help with high compression, and it's only a head gasket change away.
I just Googled quench, and it only displayed something about hot iron and cold water. so, here is a thread to get ya started.
http://www.ls1tech.com/forums/showth...ghlight=quench
Here is some info on running higher compression and having your engine live.
http://www.popularhotrodding.com/tec...ech/index.html
Hey, that's an excellent article, especially since I'm such a novice on this topic. Thanks!
I've got a 180 thermostat in in now; I'll try a 160, as well as blocking the cross over on the intake.
What about spark plugs? Should I be look at something other than stock? I'm using the R44T's now.
Wow! That's a topic I knew nothing about. Guess an old fart still can learn something new, thanks!
If you run hard in the cool morning air(before the engine gets hot),does it ping?
