Head gaskets
Old Mar 3, 2008 | 10:14 PM
Bowerss2's Avatar
Bowerss2
Default Head gaskets
I am putting in my top end kit, and am wondering what the stock bore of a 1980 l48. I am ordering the new gaskets, thanks,
Steve
Old Mar 3, 2008 | 10:17 PM
Scott Marzahl's Avatar
Scott Marzahl
Is your goal to achieve some more compression? Are you looking for a particular thickness? Is this for cast or aluminum heads. The standard bore is 4.0"
Old Mar 3, 2008 | 10:42 PM
Bowerss2's Avatar
Bowerss2
I am going to put a thinner one in there to get the compression up. To be honest i have no idea which head gasket to get. I am getting brodix ik180s, For example the bore measurement that is on the gasket, any suggestions?
Old Mar 3, 2008 | 10:47 PM
Scott Marzahl
You can't go wrong with the GM head gasket, P/N 10105117, .028" with stainless steel faces for aluminum heads. Its what is used on the GM crate engines with al heads. Nice pick on the IK180's!
Old Mar 3, 2008 | 10:51 PM
Bowerss2's Avatar
Bowerss2
thanks, i have basically gone nuts. my engine build started as a mild build. I am now putting dual quads on......
Old Mar 4, 2008 | 03:15 AM
RIJVETTES's Avatar
RIJVETTES
You spent the big bucks for a good set of Brodix heads- you might be advised to call them for a recommendation on a head gasket before you bolt them to the block. Hope they work out good for you.
Old Mar 4, 2008 | 04:27 AM
JustinD's Avatar
JustinD
I got these: http://store.summitracing.com/partde...4&autoview=sku to boost my compression.
Old Mar 4, 2008 | 01:33 PM
lincoln9's Avatar
lincoln9
First find out how far your piston sit below the deck, probably .025 but if you check, you'll know for sure, if you need .015 thick head gasket so you have .040 qwench which is what you want. Then figure out how many CC's you pistons are dished so you can can order the right combustion chamber heads. You don't want to go over 9.5:1 with iron heads or 10.5:1 with aluminum on a street engine. Now start pulling your engine apart and make the measurement needed, so we can give you accurate advice on the parts you'll need for this build.
To Head gaskets
