Steering column shenanigans
Well, now I have a nice, shiny new turn signal lever, and I don't know what to do about the gaping hole where it should go. What do I need to replace?
Okay, say I was in the mind to head on over to the local salvage yard and dig around, what's the name of that bit of the column - y'know, the bit the levers screw into? I'll try the loctite route, but assuming that I'll **** it up (and I will), it wouldn't hurt to have getting another bit as a backup plan...
If you search Jim Shea you will probably find a hundred posts dealing specificaly with the C3 steering column, where to get pieces etc. Also the link to his web page show diagrams to help you identify the parts inside the column that you can't see but are going to need. Good luck.
I made an error on this, i was looking at a pic of my interior of my car and i realized the **** that screwed out wasn't my blinker but instead my tilt instead...sorry for that guy
The only place that I have found it listed is at the following:
Doc Rebuild 1-800-866-9362 (hopefully he still has the part.)
Tilt Lock Shoe Release Lever 77-82 6521156
You are going to have to disassemble the upper end of the column to replace this part.
My Disassembly & Repair papers do not address this exact part but it pivots on a pressed-in pin and you will come upon the part as you disassemble the head.
These papers may be of help:
Go to www.corvettefaq.com
Click on Jim Shea's Steering Papers
Click on Corvette Steering Papers
Scroll down and download the T&T Disassembly & Repair Papers #1, #2, & #3
Download the T&T Disassembly & Repair Pics #1 & #2
Jim
