Gas Tank Selection
Old Mar 5, 2008 | 12:19 PM
willem wallace's Avatar
willem wallace
Default Gas Tank Selection
About to pull the trigger on a new gas tank for my frameoff, and want to double check my selection. I am not doing a NCRS frameoff, just want the correct application for a fuel return line set-up on passenger side. I am going to order GM-33E, correct? Car is a 1971 roadster, on a beautiful 1973 rustfree southern frame. Anything else I should look at before ordering?
Any info is appreciated!
Old Mar 5, 2008 | 12:53 PM
markdtn's Avatar
markdtn
Where are you ordering it from?
Old Mar 5, 2008 | 04:29 PM
Alan 71's Avatar
Alan 71
Besides the return line on the passenger's side the tank should be set up for the plastic vapor valve mount on the driver's side.
Regards,
Alan
Old Mar 5, 2008 | 05:51 PM
willem wallace
Default Plastic Vapor Valve
Glad I asked, what is the "plastic vapor valve", and what is its function. The tank I am replacing, has an outlet tube on drivers side, but I thought that it was to accomodate the EEC system, and was not necessary on a new tank if not putting EEC back on car. Please fill me in!
Old Mar 5, 2008 | 05:53 PM
willem wallace
Default Ordering
Not sure, what is the best place?
Old Mar 5, 2008 | 05:55 PM
gq82's Avatar
gq82
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
I believe you should be ordering a GM-33D unless it's an LT1. Check the Quanta site out.
http://www.quantaproducts.com/prodin...?number=GM-33D
Old Mar 5, 2008 | 11:16 PM
NHvette's Avatar
NHvette
I agree that 33D is likely the correct one.
The EEC vent valve attaches to the drivers side of the tank
and then connect to the charcoal canister in the engine
compartment. The valve used to be unavailable, but now
can be bought as reproduction. I would consider either
plugging the vent outlet and using a vented gas cap.
You could also go with the 33E tank (no EEC outlet) and
a vented cap.
vapor separator: http://www.zip-products.com/Zip/prod...DD5AAA71221266
Old Mar 6, 2008 | 05:47 PM
Alan 71's Avatar
Alan 71
WW,
I'd go with the 33D as has been suggested, and very well explained. But I'm a VERY stock kind of person.
Regards
Alan
PS: For women I prefer 32 B or C. It's a matter of proportion and usefulness.
To Gas Tank Selection
