76 transmission leak
Old Mar 6, 2008 | 11:55 AM
pete44's Avatar
pete44
Default 76 transmission leak
Hello again..Have a 76 with the TH350 or TH400 (not sure)..Anyhow I have a leak on passenger side of tranny..It comes and goes..It seems to be coming from a 4 to 5 inch "hose" with a clamp on each end...I have looked at my AIM with no luck.When I checked my fluid level it was a pint low..Any ideas?......Thanks,Pete
Old Mar 6, 2008 | 12:40 PM
Scott Marzahl's Avatar
Scott Marzahl
I can't thing of any hose on the passenger side of your tranny unless it is up by the radiator, there should be hard lines going to and from your trans case for cooling. Check the below pics. Maybe someone tried a Bubba fix.
http://blog.scottsvettetalk.com/2008...placement.aspx
Old Mar 6, 2008 | 01:19 PM
dobroman2001's Avatar
dobroman2001
Check this link out. There may be some info you can use...
http://forums.corvetteforum.com/show...nsmission+leak
Old Mar 6, 2008 | 02:08 PM
TimAT's Avatar
TimAT
The modulator on a 4oo is on the right side- could be that it's done and leaking fluid out thru the diaphragm into the hose. Maybe someone put clamps on it?
Old Mar 6, 2008 | 02:44 PM
7T1vette's Avatar
7T1vette
That actually makes a lot of sense. I think you should have a THM350 (unless you have an L-82). The vacuum modulator is connected to intake manifold vacuum via a steel line and a short piece of synthetic rubber tubing. As mentioned, when the diaphragm inside the modulator fails [ruptures], fluid is allowed to leak outward and only the tubing will keep it somewhat sealed. Take the tubing loose from the modulator can and see if red tranny fluid drips out (it won't pour out). If so, you need to replace the modulator, replace the oily synthetic tubing, and clean out the metal vacuum line from the engine. P.S. Be wary of local auto parts store "replacements" for the vacuum modulator; most are chinzy approximations of the original. They'll work...but not that well.
Old Mar 6, 2008 | 02:45 PM
pete44's Avatar
pete44
Thanks for the replies...I will try to get you some pics today to help you more....Pete
Old Mar 6, 2008 | 08:17 PM
Daves76's Avatar
Daves76
As far as what trans you have, look at the pan and that will tell you. If the pan is square with a corner cut off it is a 350....if the pan looks like "Illinois" you have a 400.
Dave
Old Mar 6, 2008 | 08:22 PM
78Vette-SA's Avatar
78Vette-SA
Make sure it's not coming out of the Dipstick tube. I've had to change a number of them (o-rings around the base of the tube) over the years. It's hard to see but if it's leaking near there a flashlight and mirror should help you be certain.
Old Mar 7, 2008 | 08:00 AM
pete44's Avatar
pete44
Default 76 transmission leak (pictures)
Here are a few pics to help out more to find problem...Thanks again!....Pete
Old Mar 7, 2008 | 10:54 AM
dobroman2001
My hoses are rubber on the Radiator end and steel where they bolt to the Tranny. I have a TH350, not sure what you have but maybe there is a difference between the TH350 and what you have. Either way, looks like those could be leaking but it really could be several things there. It could be the hoses, it could be the Detent cable "o" ring, could be the 1-2 Accumulator "o" ring, could be the dipstick tube "o" ring or it could be coming out of the top of the dipstick tube. You are going to have to clean it really good and go from there... Hope this helps. I had posted earlier with a link, that link has a good diagram/diagrams showing all the areas mentioned above.
Old Mar 7, 2008 | 12:14 PM
tommyleea's Avatar
tommyleea
Looks to me like your return line has been spliced with a rubber hose. Sometimes this is done to flush the system at home. I would change out that rubber hose, clean it up, and go from there. Cheers..
Tommy
Old Mar 7, 2008 | 12:40 PM
7T1vette's Avatar
7T1vette
Cooler lines between the radiator and the transmission are steel. It looks like someone cut the lines coming out of the transmission and put some rubber "jumper" tubes in their place. Check your AIM and parts catalogs to see what you are supposed to have; there should be two steel lines (fluid "out" and fluid "in") to the transmission. I would be really concerned about having synthetic hose on transmission lines.
Old Mar 7, 2008 | 01:11 PM
pete44's Avatar
pete44
Thanks for all the replies...I will clean that up good to start..Any suggestions on a good cleaner?...I have tried Simple Green and other assorted "bottle" cleaners...I have a pressure washer but I know it would be a mess to clean it up on the driveway...(perhaps a car wash)....BUT..I agree I need to change out the lines and make them "all metal from radiator to tranny..I tightened up the clamps around hose on both ends..(they were a little loose)..Thanks,Pete
Old Mar 7, 2008 | 01:54 PM
tommyleea's Avatar
tommyleea
Get some brake cleaner and spot spray with some rags. Sometimes you can't get that top line loose without dropping the tranny down for access. If you change the hose out use oil cooler/transmission cooler hose. Tightening the clamps at this point won't help. You need a new line/hose. You could use the oil/tranny cooler hose in the interim. Cheers. Tommy
Old Mar 7, 2008 | 03:47 PM
Glassbowtie77's Avatar
Glassbowtie77
That is not factory, someone's been under there and did a Bubba repair. You need to buy the original steel lines that go from your trans to in front of your cross member. The rubber hoses should only be from the radiator to the steel lines in front of the cross member running vertically. I bought my new repro's from Corvette central for about $60.00.
To 76 transmission leak
