Dont forget to flush!
Old Mar 6, 2008 | 02:12 PM
redson's Avatar
redson
Default Dont forget to flush!
http://www.valvoline.com/carcare/art...cid=2&scccid=1
Old Mar 6, 2008 | 02:16 PM
Jud Chapin's Avatar
Jud Chapin
St. Jude 15 Year Donor
St. Jude Donor '11 thru '25
Good advice!
Old Mar 6, 2008 | 02:33 PM
Durango_Boy's Avatar
Durango_Boy
Yep, especially if you ave invested money in a nice aluminum radiator it's even more important to remember that you need to use distilled water instead of normal tap water.
Old Mar 6, 2008 | 03:20 PM
GaryS's Avatar
GaryS
And don't forget to drop the block drain plugs too. That gets rid of the substantial amount of water that remains in the low point of the block.
Gary
Old Mar 6, 2008 | 03:28 PM
Jeffery73's Avatar
Jeffery73
St. Jude Donor '08-'09-'10-'11-'12-'13
Problem is, what do you do with the old antifreeze. Noone around here will take it.
Old Mar 6, 2008 | 03:31 PM
Jud Chapin's Avatar
Jud Chapin
I live in Palm Beach County, FL and they have a waste facility that takes about anything, including AF. Call your local waste collector and they should be able to point you in the right direction.
Old Mar 6, 2008 | 03:35 PM
damlie's Avatar
damlie
Just got done doing mine last night.
Old Mar 6, 2008 | 05:01 PM
Durango_Boy
Gary
Good call. I installed the same kind of drain valves as would go in the radiator, in my block. I just get under there, open the valves, and the little stream of coolant is easy to catch with a pan with no drips or splashing.
Old Mar 6, 2008 | 05:13 PM
Alan 71's Avatar
Alan 71
DB,
You drive me CRAZY. Do you stay up at night thinking up ways to make your car non-stock? Come on give me a break, you need to put some kind of code in your replies so I know which ones to skip!!!
Regards,
Alan
PS: You DID teach me how to post photos.
Old Mar 6, 2008 | 05:16 PM
Durango_Boy
Originally Posted by Alan 71
DB,
Regards,
Alan
Just put me on your ignore list. (Takes me about five minutes to drain my block and close it all up again, with no mess.)
Old Mar 6, 2008 | 06:36 PM
redson's Avatar
redson
What kinda valves? Where'd you get 'em?
Old Mar 6, 2008 | 06:37 PM
redson's Avatar
redson
Originally Posted by Jud Chapin
Good advice!
Then theres the Prestone flush kits where you put a fill point in the heater hose,etc. Anyone like using those?
Old Mar 6, 2008 | 06:41 PM
Durango_Boy
Any parts store. The bore in the block is the same as the bung in the radiator, so any radiator drain will work. They also put them in the bottom on air compressor tanks. Same size too.
Old Mar 6, 2008 | 06:51 PM
redson's Avatar
redson
Hey,thanks! I may do that.Sure wouldnt want to bump them open on my lowered car though either....
Old Mar 6, 2008 | 09:36 PM
ENG40's Avatar
ENG40
If you go to a marine store and get the drain ***** for a marine engine the center part of the plug will come out if need be. It comes in handy if the block accumulates rust or sediment you can remove the center and rod it out with a piece of wire.
To Dont forget to flush!
